HELLP!! pLEASEE !
Old Mar 12, 2010 | 04:56 PM
rminrx8's Avatar
Exclamation HELLP!! pLEASEE !
i have a 2004 rx8...everytime i press on the gas pedal to accelerate, my car delays in speeding up. in 1st gear it is soo slowww and it doesnt speed up unless i revv the engine real high. basically it doesnt accelerate but my RPM does go up. I have NO IDEA what is goin?
Old Mar 12, 2010 | 05:12 PM
tubingchamp's Avatar
What mawd bug?
I THINK your FONT size is too LARGE BRO.
I think your clutch is slipping.
Old Mar 12, 2010 | 05:18 PM
HomicidalApple's Avatar
yea dood it sounds like you need a new clutch. if you have a warranty they should take care of you for free.
Old Mar 12, 2010 | 05:23 PM
prighello's Avatar
^+1
Sounds like your clutch is slipping bad, but you should have noticed it chatter while building up to the failure. I blew a clutch one time and it behaved just like you are describing. I could barely move through an intersection while flooring it the entire time. Car would rev, but hardly accelerate. Thing is, I knew it was going to fail because it slipped from time to time before completely dying.
Old Mar 12, 2010 | 07:19 PM
zoom44's Avatar
clogged cat
Old Mar 13, 2010 | 05:00 PM
04RX8man's Avatar
Rotary Powered Countryboy
^yes....is it only when the car is hot...or all the time?
test the clutch: 1st gear pull handbrake up...try to take off..does it bog down and stall does it not bog and barely try to move forward...
Old Mar 14, 2010 | 07:17 AM
rminrx8's Avatar
ill try wat u said bro....nd ill reply as soon as i do it....but like i said even when i leave an intersection its hard to accelerate....
Old Mar 14, 2010 | 07:18 AM
rminrx8's Avatar
ZOOM 44 ---- wat should i do if it is a clogged cat ?
Old Mar 14, 2010 | 07:54 AM
rminrx8's Avatar
prighello--- i have the same thing happening as wat u r describing...just the fact that there is no slipping on the clutch
Old Mar 14, 2010 | 08:16 AM
rminrx8's Avatar
CoUld it be that i might just need to flush out the clutch system??
Old Mar 14, 2010 | 08:35 AM
xsnipersgox's Avatar
One Shot One Kill
if its clogged cat, replaced the cat, if it's bad clutch replace it clutch, u know, simple..
John_23
Jan 30, 2014 06:32 AM
MaRxtin
Dec 27, 2010 05:27 AM
rx8guy86
Apr 1, 2007 08:09 AM
cashcowbp
18
May 14, 2004 11:02 PM
Need For Speed
RX-8 Multimedia/Photo Gallery
10
Mar 29, 2004 01:36 PM
