Loss of Performance below 4500 RPM???
Old Mar 10, 2010 | 12:33 PM
novelwriter333's Avatar
I recently had my first experience with flooding. After taking care of that and changing the spark plugs I've noticed a dramatic loss of acceleration power except above 4500 RPM. My '06 RX8 only has 37,000 on it. Any suggestion on how to get it revved up again would be greatly appreciated.
Novelwriter333
Old Mar 10, 2010 | 01:56 PM
invasion08's Avatar
When was the last time you replaced your ignition coils? If never i would replace them asap. Hopefully your cat is not dead from the flooding. If it is then go to the dealership and get it replaced for free, your still under the federal emissions warranty.
Old Mar 10, 2010 | 02:00 PM
xun4gvn4everx's Avatar
True love is blue x2
Yup, sounds like a coil/plug/wire issue. Flooding can build up oil on your plugs and ruin them
Old Mar 11, 2010 | 07:37 PM
Info appreciated
Thanks for the info. It appears the concensus is I need to change my ignition coils and plug wires. I don't know about the cat being dead? The last time I fed her, she was still alive.
Novelwriter333
Old Mar 11, 2010 | 08:17 PM
zoom44's Avatar
no air out no air in
Old Mar 11, 2010 | 11:30 PM
hakuna matata!
Novelwriter333
Lol, can't tell if that was sarcasm..
Old Mar 12, 2010 | 10:47 AM
Novelwriter333
Well played good sir, well played
Old Mar 12, 2010 | 05:03 PM
DeViLbOi's Avatar
The devil made me do it
With things consistantly happening at 4500 RPMs Im with Zoom saying you have a problem somewhere in your intake system. With the VFAD opening completely at 5500 RPMs I would look for a leak somewhere along the lines there.
Old Mar 12, 2010 | 06:06 PM
nate340's Avatar
zoom was saying no air out no air in as in cat issues. id say cat as well usually a flooded car usually lose its car after wards but i cant see it being better at higher rpms.
dirty plugs just pull them and do a quick clean and see if that helps. plus its free for you to check the plugs
Old Mar 13, 2010 | 11:18 AM
zoom44's Avatar
the heat/pressure gets to be enough at higher rpm to overcome the problem. seen it here with a members car. Several of us all drove it independantly and came to the same conclusion. when he got a tech to open the cat, literally the ceramics poured out in pieces.
Old Mar 13, 2010 | 11:28 AM
nate340's Avatar
makes sense. cat coils plugs seem to solve every 8 problem except low compression.
Old Mar 15, 2010 | 11:30 AM
^ That is because it is a domino effect. When one goes, it takes the rest down the line with it. Order: Coils -> Wires -> Plugs -> Cat. Also, they are the most neglected in regular maintenance.
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
05rx8mazda
Nov 28, 2015 09:42 AM
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
tgaffner
Sep 7, 2015 08:49 PM
