Wrong rotors?????
Old Mar 9, 2010 | 12:41 PM
16bars's Avatar
Wrong rotors?????
I bought some rotors from rotor pros and they sent me these. (attached) Now you see there is a good difference in thickness between the old and new. My caliper bracket will not fit over this new rotor. Rich from rotor pros told me the difference is from being worn down. I don't think so. Look at the length of the pins in the rotors. Anyone can help???
Old Mar 9, 2010 | 12:46 PM
Huey52's Avatar
Registered Zoom Zoomer
Rotors don't wear that much... I'm just sayin'.
Old Mar 9, 2010 | 01:23 PM
200.mph's Avatar
FULLY SEMI AUTOMATIC
is your car a stick or auto? they have different brakes
Old Mar 9, 2010 | 02:34 PM
justjim's Avatar
justjim
Yeah what he^ said. From the Brake FAQ on this forum(https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/brake-faq-167264/) : "The base AT model has 11.9 in. (303 mm) diameter front discs while the AT with sport suspension and all MT have larger 12.7 in. (323 mm) diameter front discs. Both models have the same 11.9 in. (302 mm) diameter ventilated rear discs and floating calipers."
Which do you have and which did you order?
Measure the diameters of what you have and what you ordered and see if they are the same or different.
Old Mar 9, 2010 | 03:23 PM
lilring's Avatar
Finally a MT
and make sure you dont have the rotors mixed up. The front and rear rotors have different thinknesses
Old Mar 9, 2010 | 03:37 PM
expo1's Avatar
He's as bad as Can
The below thread contains photos of brake rotors with measurements, it might be helpful.
https://www.rx8club.com/series-i-tech-garage-22/rotor-pad-install-problem-126743/
Old Mar 9, 2010 | 08:49 PM
05rotary's Avatar
by looking at the pic, the gap between the two contact plates of the new rotor is bigger than the one at the right (old one). They are different . If you fixed it by now please post it, I am looking for new rotors as well, so I will keep reading...
Old Mar 9, 2010 | 09:16 PM
@!!narotordo's Avatar
FLAME ON!
^www.racingbrake.com ftw!
Old Mar 9, 2010 | 10:08 PM
lilring's Avatar
Finally a MT
^ second that! Racing Brake is the best!
Old Mar 10, 2010 | 08:02 AM
Huey52's Avatar
You can't lose with Racing Brake slotted/curved vane rotors.
Old Mar 10, 2010 | 08:30 AM
16bars's Avatar
Ok I fixed them. I have an auto by the way. What had happened was at first Rich sent me the manual rotors. The smaller ones i had gotten i thought went on the front since the bigger rotors did not fit on the front or rear. I installed the smaller one and sent the bigger ones back. The new rotors that were resent in the pic belong on the front and the smaller (that i put on the front, lucky I didn't die!) on the back.
Old Mar 10, 2010 | 08:35 AM
Rota II's Avatar
Its better the 2nd time
I bought a set from Rotor Pros and sent them back.
I have bought my last 3 sets (2 for my 04 and 1 for my 07) from R1 and have had great success!
Old Mar 10, 2010 | 08:52 AM
cjkim's Avatar
^noob
my friend had a similar experience for an fx35. They sent the correct front rotors, but sent the wrong rears... (the diameter where the rotor hub would be fitted over the rotor was wayyy too small)
I've heard pretty good things from them, but would honestly take my money else where after that incident (long story, but we had to get some cheap autozone rotors to ride on until he shipped replacements)
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
jamespond24
Dec 1, 2015 11:11 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Learners_Permit
Sep 27, 2015 07:38 PM
