Squeaky Brakes!
Old Mar 8, 2010 | 07:40 PM
boarderjosh10's Avatar
Resident Cool Guy
Squeaky Brakes!
My brakes squeak really bad almost all of the time when I slow down and stop and when I have my foot on the brake when I go into reverse. I already had two shops say that my brakes are fine. I even had a shop put new rotors on about 5000 miles ago and the brakes still squeak. The sound is sometimes so unbearable because the squeak changes tone as I press the brake pedal down farther. I was wondering if there are any things I could do to make them stop squeaking. I am thinking of putting new pads on because I was told that uneven wear on them can cause squeaking. But I would really like to not put pads on and still have the squeaking.
thanks!
Old Mar 8, 2010 | 08:02 PM
cyclone1208's Avatar
new pads is your only hope.....i had the same problems as yours
Old Mar 8, 2010 | 08:17 PM
Resident Cool Guy
what kind of pads did you get? I don't know if I should go with the oem ones that have been on my car.
Old Mar 8, 2010 | 08:45 PM
MarcMiller's Avatar
Rx8 FTW!
on my 98 contour my brakes squeaked exactly like your describing. I had disc brakes in the front and drums in the back..for the front i used anti brake spray..had to take the pads off and sprayed behind them..fixed the front problem.
As for the shoes i had to replace my pads and the actual drums...fixed them perfectly.
Try the anti squeak brake spray.
Old Mar 8, 2010 | 08:48 PM
Jon316G's Avatar
Grasshopper
Another thing to consider:
http://www.finishlineperformance.com...01-06-1568.pdf
Old Mar 9, 2010 | 07:20 AM
Dont go with OEM ones. Alot of members here go with Hawk Brake Pads. I have Wagners but wouldnt recommend it cuz it dusts alot. It did fix my squeeky problem
Old Mar 9, 2010 | 07:57 AM
Huey52's Avatar
Registered Zoom Zoomer
Hawk Ceramic pads, properly bed-in, silenced my brake squeaks. Low dust as well.
hufflepuff
May 30, 2016 10:45 AM
Road Cone
Nov 6, 2015 01:52 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
