when to start using summer tires?
Old Mar 8, 2010 | 10:34 AM
Bigbacon's Avatar
2006 WB AT
My car came with winter tires and I have a set of wheels with summer tires ready to go, but what temperatures should you be looking for in order to use them?
It's starting to get nicer how around here 50s-60s but in the mornings its still kinda chilly, like 30s.
Old Mar 8, 2010 | 10:36 AM
TopGear8's Avatar
mkuhnracing.com
When it is above 40 degrees at night. If you have summer tires, Temp's below 40's may cause flat spots on the tire.
Old Mar 8, 2010 | 12:12 PM
Huey52's Avatar
Registered Zoom Zoomer
My '8 comes out of hybernation April 1st each year. But if late cold/snow I still drive the Jeep day to day until it passes.
All tires will of course warm up in use, but summer tires when it's initially cold are pretty dicey.
Old Mar 8, 2010 | 12:17 PM
Lord ET's Avatar
Is that a bike rack?
I have had summer tires on all winter here in TX. I didn't drive in the snow or ice though. The summer tires can handle the 30's just fine. exta spts
Old Mar 8, 2010 | 12:27 PM
Bigbacon's Avatar
2006 WB AT
looks like I have some time to wait.. average lows are like 30s even to the end of the month...
I was hoping to get a very good cleaning of the car done and wheel swap soonish.
Old Mar 8, 2010 | 01:11 PM
robrecht's Avatar
It really depends on whether you have alternative transportation in case of late snow or, if not, if you don't mind switching back to snow tires. Depending on the summer tire, most are fine in the upper 30s, as long as you realize the traction won't be nearly as good as in warmer weather, but it may still be better than your snow tires or even many all-season tires at the same temperature. Flat spots in the morning are not really a problem on most tires, they fix themselves in a couple of minutes. Note, however, that there a few very high performance tires that can be damaged in very cold temperatures, but most will be fine.
Duren1
Mountain For Sale/Wanted
Jan 11, 2017 09:07 AM
WingleBeast
22
May 23, 2016 09:22 PM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
CMRine04
Jul 29, 2015 02:07 PM
Belalnabi
Jul 17, 2015 07:48 PM
