No power anything..
Old Mar 6, 2010 | 10:29 PM
GerryE's Avatar
No power anything..
Well as I am getting ready to prepare my engine out of a 2004 RX-8 for a rebuild, I was hoping to start the vehicle to make sure there is no other problems besides the engine itself that should be addressed.
Now for a quick run down of an update to help the gurus assess possible problems here is a short span of the vehicle activities
November: Started car by jump starting and moved into current storage and pulled battery.
December: Attached cables from a battery in a running car to the positive and negative lines in the rx8. Had full function of all power options but not enough power to attempt to start.
February: Again attached cables from a battery in a running vehicle to the postive and negative lines in the 8. This time I got absolutely nothing except for a very weak security light and a charging system warning light.
Today: Put two different batteries in the 8 with a charger attached and have seen nothing within the vehicle.
The battery that was in the vehicle before I pulled it was practically dead. I saw it from the light that having a battery placed in the bay that was dead is just the same as just hooking the cables directly to the positive and negative line if I was attempting to jumpstart. That is why I decided to just hook directly up.
Now that I think about it, it was a pretty stupid idea. I do not see how it would affect the power system though. Unless it possibly shorted a circuit or blew a fuse?
Also, I have been highly confused if I have the correct idea on the orietation of the charge of the lines. I remember distinctively that the line with the large fuse or whatever on it is positive (+), but is the line that is somewhat attached to it with the red line intertwined with it also (+)? Or is the solid black line the other (+)?
Currently I have the line with the fuse on it and the line with the red line intertwined with it connected to the positive (+) and the solid black line connected to the (-).
Thanks for all of your help,
GerryE.
Shankapotamus3
Mar 14, 2021 03:53 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
D13
Oct 1, 2015 07:55 AM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
