LUg nut bolts
Old Mar 6, 2010 | 12:27 PM
mindlessadema's Avatar
Spence
LUg nut bolts
Someone tried to steal my wheels and messed up one of the bolts sticking out. whats the beat way to fix this/
rethread?
or is it easily replaceable?
Old Mar 6, 2010 | 12:31 PM
05rex8's Avatar
sold the 8... :(
front or rear studs?
if its the front, very easy to replace
the rear is a big job...you have to remove the spindle from the axle to get to the studs...some notch out the spindle to do it too, but I don't know how well it works
Old Mar 6, 2010 | 12:35 PM
Spence
Its the rear, would a mechanic be able to do it easily?
Old Mar 6, 2010 | 12:38 PM
05rex8's Avatar
sold the 8... :(
yeah a mechanic can do it, it won't be cheap though
I would try to rethread it first before you take it to a mechanic, which I have done with success.
you can rent a decent tap and die set at auto parts stores that should be able to handle it
it will not work with a cheap die however, it will ruin the die.....I have done it before, lol.
Old Mar 6, 2010 | 01:53 PM
chaudrx7's Avatar
GO GAMECOCKS!
rear studs
https://www.rx8club.com/showthread.p...ar+wheel+studs
Here's the link on my travails trying to replace two rear studs I broke. Definitely try to fix the threads. The studs are super-hardened steel so be careful.
Failing that, you're about to get a real education on your rear suspension and axles!
Bon Chance!
Old Mar 6, 2010 | 01:57 PM
05rex8's Avatar
sold the 8... :(
^did you ever get it all back together?
200.mph
Dec 10, 2018 03:49 PM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
He||hammer
Sep 29, 2015 09:40 PM
RXBae
Sep 14, 2015 03:54 AM
