AEM CAI Sound
Old Mar 5, 2010 | 02:03 AM
essmac13's Avatar
White Power
Question AEM CAI Sound
Okay guys i know this is a newb question, but i'm a newb so bare with me :D I just go my AEM CAI installed and I have never used CAI in my life. I am making sure that the high pitch sound that comes from the filter area is normal. It doesn't make much sound when I start it but after about 5 mins of driving it makes a high pitch sound. I assume this is normal but I just want to double check. Thanks in advance
Old Mar 5, 2010 | 02:13 AM
ZumnRx8's Avatar
RX8 & RX7 owner
Yes, like a whistling/ whining/ ringing in ear
Old Mar 5, 2010 | 08:50 AM
TheWulf's Avatar
My 8 looks like a Smurf
It's the sound of success
Old Mar 5, 2010 | 05:56 PM
essmac13's Avatar
White Power
thanks guys. it sounds pretty sweet. just making sure its normal.
Old Mar 5, 2010 | 06:09 PM
nx04's Avatar
zoom-zoom
it sounds really loud red line first and double tap the gas its insane
Old Mar 27, 2010 | 03:02 AM
maskedferret's Avatar
Oooh, shiny!
I just installed mine today. I have never driven a car with an aftermarket intake nor exhaust and I do not know what the AEM CAI should sound like.
My perception of it is that it sounds like your typical fart-can exhaust (except from the front of the car) from the inside when near WOT, yet mostly indifferent otherwise; is that about right? I'm not noticing much of a "high pitched" sound.
I am running a stock exhaust system, so there's no confusing the sound for the exhaust.
Old Apr 1, 2010 | 11:58 AM
tza0001's Avatar
Dum Spiro Spero
^ The intake just makes the car louder. Very noticeable after 6000 rpms. Further, you should be able to hear some whistling noise (something similar to a jet engine sound but not as loud). That's what I hear with mine
Old Apr 7, 2010 | 02:21 AM
essmac13's Avatar
White Power
you won't hear the whistle/high pitch til after a ten minute drive or so. Atleast from my experience. I don't hear the high pitch sound until after the engine is warm and RPM's have been high.
Old Apr 10, 2010 | 05:58 PM
mindblow21's Avatar
Hey guys I just ordered ms cai, I know that ms and aem or similar in design and install; any pointers or ideas that will help with my install as I plan to do it myself. Thanks for your help.
Old Apr 10, 2010 | 08:15 PM
Grungepup's Avatar
Oilfield trash
i would just advise to ensure that the pipes are perfectly lines up, any deviation that it will have a negative impact on the performance. If you think the whine is out of the ordinary, make sure the screens are mounted right in the couplers, yes there is a wrong way to do it (the grooved portion should be facing away from the throttle body). Make sure all the clamps are tight, especially the one on the filter. Avoid water as much as possible, if you feel it start to stumble after washing it or driving in the rain, take it apart and clean out the pipes because water has gotten into the system. Clean the MAF sensor often as well, the water will create havoc with it.
Old Apr 10, 2010 | 10:43 PM
Oooh, shiny!
By "grooves" you mean the ones on the inside of the rubber tubes in relation to the screens? Also, does it matter the direction the screens themselves are facing? They seem to be curved in one direction. I don't think the instructions detailed any of these specifics.
Old Apr 11, 2010 | 07:42 PM
mindblow21's Avatar
Grungepup, thanks for the information, can't wait til my intake and exhaust arrive! Were any of you guys able to install the CAI without completely removing the front bumber? I am not to excited to remove the bumper but will do so if there is not way around it.
Old Apr 11, 2010 | 08:17 PM
Oooh, shiny!
Unless you can snake that tube around - which I doubt (you'll see) - there's no way around it.
Old Apr 11, 2010 | 08:26 PM
Jon316G's Avatar
Grasshopper
You need to remove the front bumper so you can remove the few clips for the stock air duct.
Then, the AEM has two bolts and spacers that secure it to the frame (which is in the front).
There is no way to do this without removing the bumper.
Don't worry about it, its actually very easy to do.
Once you do it a few times, you'll be OK with it.
Also, the AEM instructions tell you that you need to remove the front wheels.
This is not true... you can get to every thing with the wheels on.
I've lost count on how many times I've done this.
Old Apr 11, 2010 | 11:46 PM
azzuro's Avatar
So this Rotary thing...?
Anyone got recordings/video of this intake?
Old Apr 12, 2010 | 06:00 PM
mindblow21's Avatar
Cool, off with the bumper. I will let you guys know how the installation goes...youtube has videos of mazdaspeed intake sound.
Old Apr 12, 2010 | 11:01 PM
Grungepup's Avatar
Oilfield trash
yeah the bumper is easy to remove.... I have got it down to a science.... the sucker is off in less than 2 min lol.... unless there is beer involved
Old Apr 12, 2010 | 11:06 PM
Grungepup's Avatar
Oilfield trash
^+1
not to mention you have to remove the ducting and tray that ducting sits in.
You will also need to remove the crash guard to get the S pipe to fit properly.
when removing the stock intake... i would keep everything nut and bolt that is left over just incase you want to go back to stock
92trbolzr
May 18, 2025 09:04 AM
Sato Tatsuya
Oct 5, 2015 03:09 PM
Zube6115
Sep 30, 2015 12:57 PM
Racingjunkie
Sep 29, 2015 05:05 PM
