Racing Beat midpipe
Old Mar 3, 2010 | 11:09 PM
Pstone's Avatar
Thumbs up Racing Beat midpipe
Installed my Racing Beat double res midpipe tonight. It was a pretty easy install and only took about an hour total. Quality was great and the fitment was perfect. I have it paired with the factory cat-back. It sounds pretty much stock at idle, and is a little bit deeper up top in the rpms. It definitely pulls harder and also has an interesting popping sound between shifts. So far its a great product and I would recommend it to anyone else with an RX8.
Old Mar 3, 2010 | 11:54 PM
RyansRx8's Avatar
Brettward is/has a G
Sounds like it would be raspy, going with an aftermarket exhaust?
Old Mar 4, 2010 | 12:03 AM
JantzenRX-8's Avatar
Its not raspy with an aftermarket exhaust.
Old Mar 4, 2010 | 12:07 AM
Jon316G's Avatar
Grasshopper
It actually sounds pretty good.
We have a local who has it with an AP catback.
Old Mar 4, 2010 | 12:21 AM
t0m's Avatar
t0m
Ninja Geek
I have a TurboXS catback and midpipe and it smells horrible and droney and loud as all hell. Will this midpipe make it a little better in regards to sound and smell?
Old Mar 4, 2010 | 12:22 AM
Jon316G's Avatar
Grasshopper
^Sound yes, smell no
Old Mar 4, 2010 | 12:43 AM
t0m's Avatar
t0m
Ninja Geek
The only thing I really don't like is the smell inside the car. It wreaks of exhaust. Even with the windows up.
Old Mar 4, 2010 | 01:04 AM
RyansRx8's Avatar
I mean that it would probably be raspy with the factory exhaust not with an aftermarket one
Old Mar 4, 2010 | 01:41 PM
danatkins8605's Avatar
t0m you sure you dont have a leak in your exhaust or trunk that's the only thing i would think would cause smell in your cabin
Old Mar 4, 2010 | 02:07 PM
TopGear8's Avatar
mkuhnracing.com
Just get a Davesport 100CPI cat installed in your midpipe. Won't have as bad of a smell.
Old Mar 4, 2010 | 08:24 PM
Pstone's Avatar
There's no raspy what-so-ever with the midpipe and stock exhaust. Yea, it does have a slight smell when I'm sitting at a stoplight for a few minutes if I have the sunroof open. I just got the windows tinted today so I can't put them down for a few days. Hopefully it will smell less as all the penetrating oil burns off that I used on the bolts. Had a little scare today, i took 2nd to 9200 and shifted into third, loud pop from the exhaust and then the car hesitated for a second. At first I thought I might have blown a seal but it's still driving perfect.
Old Mar 4, 2010 | 08:26 PM
Pstone's Avatar
I've also found that if I switch the air to cabin circulation only it pretty much eliminates any exhaust smell while sitting at a stoplight.
Old Mar 5, 2010 | 10:56 AM
Boyd's Avatar
Anyone have any idea how much the dual res weights?
Old Mar 5, 2010 | 11:15 AM
Pstone's Avatar
I would say its about 10 lbs ligher than the stock midpipe. The stock one is heavy as hell.
Old Mar 5, 2010 | 04:32 PM
turbo7's Avatar
Hey did your engine light come on since you don't have a cat?
Old Mar 5, 2010 | 05:24 PM
Pstone's Avatar
Yea, it came on after 20 miles. Reset the ECU wt my COBB and came back again right away. Later this summer I'm going to do the RB intake and duct, along with AP UDP. Then I'll get the MM e-tune and have him get rid of the engine code.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
RX8mzda
Oct 1, 2015 10:17 PM
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
