RX8 Leaking gas from the gas tank
Old Mar 2, 2010 | 01:22 PM
dkfc's Avatar
dk
My friend's Rx8 is leaking fuel from the gas tank on the passenger side. Its constantly streaming fuel out onto the floor.
I cant tell if its from the actual gas tank or from a line.There is alot of metal shields around so Icant see.
His car is super low, and he probably hit asomething on the road.
It looks like there is two gas tanks?
ANybody with info on this?
Old Mar 2, 2010 | 06:39 PM
kingaaron's Avatar
Check for leaks around the fuel lines because the RX8's fuel tank is under the rear driver side passenger seat.
Old Mar 2, 2010 | 06:46 PM
Cam's Avatar
Cam
this space for rent
I believe we actually have a "saddle" style fuel tank, due to being RWD. So the tank is actually on both sides.
Old Mar 2, 2010 | 06:49 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yeah, take out the seat as described above and give a look. Could he have bottomed out hard enough to knock the fuel pump and sock loose?????
Old Mar 2, 2010 | 06:52 PM
If it's coming out the passenger side he likely punctured the tank...
The fuel lines and anything that leaks are pretty much on the drivers side.....
Old Mar 2, 2010 | 06:55 PM
Mazurfer's Avatar
But fuel is constantly running onto the floor.
I thought he meant the floor(footwell area) of the back seat?
Maybe I need a clarification from him.
Onto the ground or into the footwell area?
Old Mar 2, 2010 | 06:58 PM
If he has fuel running into the interior he has some kind of fuel line the rest of us don't. There is no fuel lines inside the car...or anything that could get in there either.....all the lines run under the car
Old Mar 2, 2010 | 07:01 PM
Mazurfer's Avatar
I know all lines are under the car, that's why I thought maybe the access to the pump got compromised????? I probably mis-read his meaning.
Old Mar 2, 2010 | 07:03 PM
There is no pressurized fuel in the passenger side...and there are no external fuel lines over there....there are some rollover and vent valves on the top of the tank..but if they were leaking the PCM would freak out anyway.....
Best guess is it's the floor/ground..and he has a hole
Old Mar 2, 2010 | 07:08 PM
Mazurfer's Avatar
Okay, I give!
Old Mar 2, 2010 | 07:14 PM
HUH? You give what?
Old Mar 2, 2010 | 07:18 PM
Mazurfer's Avatar
I give up........you win!
Old Mar 2, 2010 | 07:32 PM
I thought we were having a discussion.....wasnt trying to win anything........
Just trying to get clarification on the issue...
Old Mar 3, 2010 | 05:33 PM
secret8gent's Avatar
the enemy in the mirror
lhd or rhd?
Old Mar 3, 2010 | 05:50 PM
Easy_E1's Avatar
Sounds like he punched a hole in the bottom of the tank.
Old Mar 3, 2010 | 06:23 PM
alnielsen's Avatar
There was a tank for sale on here. Just say'n.
Old Mar 3, 2010 | 11:26 PM
Snrub's Avatar
You can also have tanks repaired. Call around to local shops. I had a tank patched in a different car that rusted through. The patch lasted for 2 years and I sold the car after that.
Old Mar 4, 2010 | 12:11 AM
CRO8TIA's Avatar
Are there metal and plastic-poly something tanks in the 8, cause mines the latter ?
Old Mar 4, 2010 | 12:30 AM
They are plastic.....
Old Mar 4, 2010 | 01:18 PM
zoom44's Avatar
no no you definitely were swinging the club of truth and gave him a couple of lumps
Old Mar 4, 2010 | 01:39 PM
Guess I'm kinda obtuse....................
Old Mar 4, 2010 | 01:43 PM
zoom44's Avatar
its a joke man!!!!
Old Mar 4, 2010 | 01:51 PM
I wasn't upset.......just think it's funny the way things get interpreted
Old Mar 4, 2010 | 09:15 PM
Mazurfer's Avatar
I understand and I'm thicker than that. If the OP would've used the term "garage floor" or "ground" instead of "floor", we wouldn't have had any discussion at all.
Guess I take things to literally sometimes. I also figured that a hole in the tank or in a line would've been fairly obvious and not worth really posting about???????
Old Mar 4, 2010 | 09:20 PM
zoom44's Avatar
where would the fun be in that?
