Simple question
Old Mar 2, 2010 | 01:00 AM
ms70616's Avatar
Simple question
Simple question that I cant seem to find a simple answer to. Can anyone tell me the difference in an AFR gauge and a Wideband AFR gauge??? Thanks.
Old Mar 2, 2010 | 02:00 AM
hakuna matata!
i dont even know how to answer that question..
there is no difference but it depends why you ask..
Old Mar 2, 2010 | 07:11 AM
Huey52's Avatar
Registered Zoom Zoomer
You mean what's the difference between a narrow band and a wide band Air Fuel Ratio sensor/gauge?
The wide band is far more sensitive and therefore able to read more precise ratio's. For FI applications you want wideband to facilitate better tunes.
Old Mar 2, 2010 | 12:10 PM
ms70616's Avatar
Sorry, Yes Huey thats exactly what i meant, I was just looking into them and noticed that they have both narrow band and wideband gauges. So I was wondering what the difference was. So the wideband is more sensitive and more precise than the narrow band correct? Also, with a wideband gauge you need to get a wideband sensor as well because the stock O2 sensor is not wideband right?
Old Mar 2, 2010 | 12:14 PM
hakuna matata!
narrow band gauges are absolutely useless for air fuel monitoring.
stock front o2 sensor is wideband but it won't be able to be interfaced with aftermarket gauges.
so yes, you will need a new o2 sensor with a wideband controller and a gauge.
Old Mar 2, 2010 | 02:59 PM
ms70616's Avatar
Alright that all makes since, so when you get the new wideband sensor with the controller and gauge does that new sensor replace the stock front sensor or the rear sensor?
Old Mar 2, 2010 | 03:34 PM
Huey52's Avatar
The front O2 sensor, ahead of the Cat, is the one that figures into the AFR equations (lean or rich based on O2 sensed). The rear on the Cat is just a sniffer for emissions purposes.
Old Mar 2, 2010 | 05:15 PM
hakuna matata!
whatever you do, you don't remove the front o2 sensor, the one on the exhaust manifold. the o2 sensor downstream can be removed, but that will give you a CEL.
if you have a midpipe with an extra o2 bung then that is that, but if you don't you will have to remove the second o2 sensor to screw in your new sensor for the gauge..
or your last option would be having another o2 bung welded in...
Old Mar 2, 2010 | 06:45 PM
ms70616's Avatar
Ok so Huey says that it replaces the front sensor and Alz0rz says that it either replaces the rear or weld in a completely seperate bung who is right? This is the part that i really need to know, i dont want to do it wrong
Old Mar 2, 2010 | 07:06 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Just wanna say Thanks Huey! You're one of my sources for clear diagrams and pics!
I amassing quite a collection!
Old Mar 3, 2010 | 06:46 AM
Huey52's Avatar
^ you're welcome Mazurfer, but the pictures are typically from other savvy members here. I've amassed quite a library myself. I always like a picture to review for orientation before I dive into mod's.
^^ Again, the front O2 sensor is the one you deal with for AFR calc's. The rear sensor could actually be left off, but you'd get a CEL (unless masked by CobbAP setting).
Old Mar 3, 2010 | 06:49 AM
Jon316G's Avatar
Grasshopper
Savvy... you're too kind
Old Mar 3, 2010 | 07:00 AM
Huey52's Avatar
^ and Jon is one of my principal savvy sources!
I'm not a particular fan of our Sec'y of State, but I have to agree with her in this context that "it takes a village."
Old Mar 3, 2010 | 07:03 AM
Jon316G's Avatar
Grasshopper
LOL... I recognize my Microsoft Word text box and colored arrows anywhere... oh no, secret is out...
Old Mar 4, 2010 | 09:21 PM
Mazurfer's Avatar
I grab them when I see'em.
I know a lot are from you Jon, so a big thanks to you as well!
Old Mar 4, 2010 | 09:42 PM
hakuna matata!
Huey was just letting you know what they each do. I dont think he suggested to replace the front sensor. If you replace the front sensor your car will run like crap. Removing the rear will give you a CEL, but that is it. You won't pass emissions either, but once again your cars performance will not be affected.
Old Mar 5, 2010 | 12:46 PM
ms70616's Avatar
Ok yea i know that, i know what each sensor does, i know that much. What i need to know is where to install the wideband AFR sensor.
Old Mar 5, 2010 | 01:46 PM
TheWulf's Avatar
My 8 looks like a Smurf
Sensor should come with instructions.
18" from the exhaust port, 36" if FI.
Install BEFORE the cat if you have one.
Old Mar 5, 2010 | 10:57 PM
ms70616's Avatar
awesome, exactly what i needed to know. Before the cat right, and if i have no cat then dose not really matter i guess. Thanks
Old Dec 31, 2010 | 12:08 AM
dmedz8's Avatar
Needs Boost!
ok, 7 month thread revival here but does anyone know what wire to splice for the narrow band application? i know its the second o2 sensor and it has to be a 0-1v wire (direct quote form prosport)
Jelliott5384
Oct 26, 2016 05:15 PM
p8ntman442
Sep 23, 2015 09:18 PM
Turman-ator
11
Sep 22, 2015 11:22 AM
patriotjj
Sep 13, 2015 08:09 AM
carid
Vendor Classifieds
Sep 10, 2015 09:26 AM
