drivers door wont open
Old Feb 28, 2010 | 02:51 AM
nichelle's Avatar
SK drivers door wont open
Help my drivers side door wont open. It sounds like its unlocking, the door will not open. The latch is not moving inside the car either manually nor from the keyless entry. Help
Old Feb 28, 2010 | 02:55 AM
ZumnRx8's Avatar
RX8 & RX7 owner
Trying using this little puppy, see if it doesnt do the trick.
But being serious now, can you open the Passenger door and open the driver door through the inside? Are you still under warranty?
Old Feb 28, 2010 | 03:01 AM
Jon316G's Avatar
Grasshopper
This guy managed to get it open:
https://www.rx8club.com/showthread.p...r+won%27t+open
Old Nov 4, 2010 | 01:47 AM
Grace_Excel's Avatar
Charles Bundy
If you hear the 'locking' and 'unlocking', it's not the actuator. If the door still won't open after pulling the inside and outside door handles, it could be a broken spring in the lock or the rod that connects to the door handle came came loose.
Follow this thread, as well: Driver Door Will Not Open!!!!
Broken spring:
Old Nov 4, 2010 | 08:39 AM
ArXate's Avatar
Nichelle, Grace_Excel is currently helping me get my door open through the forum. I'm almost there. I have the day off today (Thur) and hopefully I'm on the final leg to getting it open.
Use Grace_Excel's pictures and directions once you get the door panel PARTIALLY removed (you won't be able to completely remove the door panel with the door unable to open).
But first you have to pull the door panel partially out. To do that you'll need the following pics and diagrams:
https://www.rx8club.com/showthread.p...+panel+removal
http://rx8.becomeanidiot.com/puddlelights.pdf
Good luck. Get back to us if you have any obstacles along the way.
Old Nov 4, 2010 | 08:50 AM
Grungepup's Avatar
Oilfield trash
if you need help.... just pay for my airfare and hotel stay... i will come lay my hand on your door and it will open
just ask 9k, i opened his stuck door last night
Old Nov 4, 2010 | 09:03 AM
ArXate's Avatar
I'm in southern California and so is Grace_Excel, so if it comes to that, I'd just drive over to his area! Maybe Nichelle is in your area.
Anyway, I couldn't do airfare and hotel. The best I could do is craft beers from the famous San Diego microbrewery, AleSmith.
Old Nov 4, 2010 | 09:07 AM
paimon.soror's Avatar
LOL geez dude
Old Nov 4, 2010 | 09:14 AM
Grungepup's Avatar
Oilfield trash
basically we took apart the rear door handle, popped the lock but it didnt allow the front to open
but it did allow for more room to pull the door open further so we could get the panels off the front door, took the window and regulator out so we could have full access to the accuator, messed with that for about an hour ... were about to give up, i turned around pulled the handle and BAM it opened
Old Nov 4, 2010 | 01:11 PM
Charles Bundy
Nichelle, how long have you had this problem? After going through the other threads. I found this post of yours:
Old Nov 4, 2010 | 01:20 PM
Charles Bundy
Originally Posted by ArXate
I'm in southern California and so is Grace_Excel, so if it comes to that, I'd just drive over to his area!.
Oh hell, you're in San Diego? I'm off work until next week. If you still haven't managed to open it, try to make a trip half-way i.e. Aliso Viejo or Irvine (I think there's an RX-8 meet at a local Irvine IN-N-Out close to I-5) and I'll help.
Old Nov 4, 2010 | 02:45 PM
DocBeech's Avatar
I drive at Red Line.
https://www.rx8club.com/series-i-trouble-shooting-95/driver-door-wont-open-190046/ here you go
Old Nov 4, 2010 | 03:59 PM
ArXate's Avatar
Nah, I'm in LA, close to Pasadena area. I just mentioned AleSmith because almost all of their ales are extremely highly rated. For example, their stout, which is called Speedway Stout, is the highest rated stout in the world according to beeradvocate.com, ratebeer.com, and beerpal.com.
Old Nov 4, 2010 | 09:27 PM
Charles Bundy
Well, Sherman Oaks is in LA as well... Glad you were able to open your door already. Fairly quick and simple, but it's a pain in the *** to get to.
Old Nov 26, 2021 | 01:00 PM
cmaderia10's Avatar
I have the same problem
Hi. I have the same problem. My drivers side front won’t open. If you pop the suicide door open, remove actuator and rods from the door there is a white plastic piece that one of the rods were connected to. Pop the suicide open and press the white piece down and the door will open if you push from the inside.
now I need a new drivers side door because me and the lock and key guy ruined it. They have a what looks like 05 rx8 or newer at a junk yard down the street with the door intact. Is this a good swap? What about the electrical? It looks like I can unbolt the door. What about my key? It won’t open the junk rx8 door.
please help. Thanks.
chad.
Old Nov 26, 2021 | 07:13 PM
Loki's Avatar
Can you swap the lock and electronics from your door into the new one? How did you ruin it anyway?
You will need the new door's lock motor, that's usually what is responsible for the door not opening.
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
czr
Sep 13, 2015 11:37 AM
