Clutch issue
Old Feb 24, 2010 | 01:58 PM
anouktlw's Avatar
Clutch issue
Hi everybody,
I start having some issues with my clutch a couple of days ago, in the mornings and only in the mornings. When I first start, the clutch is almost all the way down, whith almost no pressure to engage any gear, but after some minutes with the engina running and pumping the pedal while warming up the car, all goes back to normal and I can drive the car without problems all day long, No slipping, hard shiftings or noises from my clutch, the fluid level is on MAX.
Could this be related to the Hydraulic clutch master cylinder loosing pressure? Any opinions, I was searching around but I couldnt find nothing related to my issue.
Thank you to all of you and any information will be really appreciated.
Old Jun 14, 2010 | 09:26 PM
Rx8Curacao's Avatar
Did you solve your problem already???
Old Aug 4, 2010 | 09:25 PM
valpac's Avatar
Ahead of its time
Having the same issue recently. Trying to track it down now.
Old Aug 8, 2010 | 11:16 AM
Rx8Curacao's Avatar
I solved my problem by replacing the master and slave cylinder!
Old Aug 8, 2010 | 10:10 PM
yiksing's Avatar
the giant tastetickles
Bleed the lines
drebbrnator
Dec 27, 2018 07:02 PM
Dokuji
Nov 1, 2016 02:51 PM
learningdriver
Aug 8, 2015 06:55 AM
thewatcher101
Aug 4, 2015 10:42 AM
yapakanichi
Jul 21, 2015 07:41 PM
