A bird living in my clutch
Old Feb 23, 2010 | 10:27 PM
jasonrxeight's Avatar
ok, 09 S2, 7000 miles on the car, clutch is not slipping, no viberation through the pedal, and engaging point is not high either.
everytime I begin to move the car, my clutch makes a squealing/chirping sound as I'm slipping it. it only makes sound when underload and slipping it
no any sound when in neutral and pedal at any position, depressing, or releasing, and its not the pedal
ok, a real recording
http://www.youtube.com/watch?v=hGNoS2gdA-c
Old Feb 23, 2010 | 10:30 PM
Easy_E1's Avatar
Release bearing or pilot bearing?
Old Feb 23, 2010 | 10:38 PM
will they make noise when in neutral?
Old Feb 23, 2010 | 10:48 PM
Easy_E1's Avatar
Release bearing when you depress the clutch.
Old Feb 23, 2010 | 10:49 PM
then nope, no sound at any position, depressing, or releasing the clutch
MazdaManiac's Avatar
Usually not.
Could also be contamination of the disc surface or a need for lube on the slave cylinder.
Or a droopy motor mount.
Or the starter harness rubbing on the chassis.
Old Feb 23, 2010 | 10:53 PM
SayNoToPistons's Avatar
Wheels, not rims!!
Could it be this?
https://www.rx8club.com/showthread.p...=squeak+grease
Old Feb 23, 2010 | 11:55 PM
I just updated the vid
Old Feb 24, 2010 | 12:20 AM
kersh4w's Avatar
Hit & Run Magnet
definitely a bird in your transmission.
Old Feb 24, 2010 | 12:28 AM
chrisis's Avatar
if you look above the pedal you can see 2 springs. grease them very well and that should kill the bird.
Old Feb 24, 2010 | 12:29 AM
if you look at the vid closely, its not from the pedal
Old Feb 24, 2010 | 12:34 AM
Wheels, not rims!!
Check the link I posted -_-.
UnrealOne
Sep 30, 2015 11:04 AM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
neoksk
Sep 21, 2015 12:31 PM
