Royal Purple Oil Check & Clarification
Old Feb 23, 2010 | 02:27 PM
RX876's Avatar
FL Royal Purple Oil Check & Clarification
So I'm getting ready to change oil at 43k miles, Had the car since it had 28k I think. Always used Castrol 5w20 conventional, changed every 3k miles, and add about a quart every 1k miles. To my understanding, the rotary engine is oil injected. The burn off temperature is much lower in conventional oil, allowing the oil to burn off without residue left behind. But I have also read many people switching to conventional with positive results.
If I were to switch to Royal Purple 5w20, what possible positive and negative effects am I looking at? Will I have excessive residue left behind, possibly leading to engine failure? Do I still need to add oil every 1k miles? Do I still need to change the oil every 3k miles? Will I actually feel results?
Thanks guys, any help would be great.
Old Feb 23, 2010 | 02:30 PM
The Reverend's Avatar
That's a lie
Here is some info from RP so take it with a grain of salt
http://www.royalpurple.com/faqs-rotary.html
Old Feb 23, 2010 | 02:43 PM
RX876's Avatar
Wow, this was a great write up from Royal Purple, but it did not mention the 13B-MSP in particular. I think it makes me feel a little more comfortable. Anyone uses this oil in particular, and what weight?
Old Feb 23, 2010 | 02:46 PM
Vlaze's Avatar
The Angry Wheelchair
In fall the last oil change I did was to Ow-40 Royal Purple. But the catch is I'm using a SOHN adapter so I don't have to worry about injecting the engine oil into the apex seals. I feed the apex seals Idemitsu pre-mix oil from a separate container.
So I can say it works fine for the engine internals....but got no feedback for you in regards to having it mix in the combustion chamber.
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
drebbrnator
Dec 27, 2018 07:02 PM
RicerX1
Jan 11, 2016 05:59 PM
Sifu
Aug 30, 2015 10:51 PM
Yayforaddison
38
Jul 31, 2015 11:28 AM
