Brake & Clutch Reservoir Cap.
Old Feb 20, 2010 | 05:15 PM
RX8.PIPE.DREAMS's Avatar
Rotary Junkie
CA Brake & Clutch Reservoir Cap.
Hi guys & gals, happy Saturday for those of you on the west coast and happy evening for the east coasters : )
I am thinking about a brake overhaul and I couldn't find the capacity for the brake and clutch fluid since the manual says that they "use the same reservoir." If I were to bled/flush the brake and clutch fluid, how many Qts would I need to refill everything. I should add that I am having my shop do brake pads and rotors too while they are at it. Thanks.
Anyone anyone who is curious, here is my proposed setup:
F & R Rotors: Centric Single-Piece, (PN: 120.45071, 12045072)
F & R Pads: HAWK HPS, (PN: HB470F.643, HB378F.565)
Fluid: Valvoline Dot 4 or Castrol LMA (ATE SB is too rich for my blood! )
-Chris
Old Feb 20, 2010 | 10:22 PM
kingaaron's Avatar
1 quart is plenty to bleed the entire system, you'll have leftovers from the job.
Old Feb 20, 2010 | 10:45 PM
umm... i love left overs.
Old Feb 20, 2010 | 10:46 PM
I quart is minimum. You can do it with that...but if you aren't careful you will need more to get it all changed out
The price difference between Super Blue and Most cheap stuff is less than $10...hardly too big a deal really
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
vapor2
May 4, 2020 03:53 AM
Chapsy
Sep 22, 2015 09:57 AM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
