Correct gaskets for midpipe?
Old Feb 20, 2010 | 12:04 AM
Pstone's Avatar
Well, I just ordered the racing beat midpipe and I'm wondering which gaskets I need exactly. I will be using the midpipe with the factory catback. Would this kit be what I need?
http://raceroots.com/index.php/produ...asket-set.html
Old Feb 20, 2010 | 12:58 AM
Jon316G's Avatar
Grasshopper
I have those gaskets on my MazSport midpipe and they work fine.
I keep the OEM gaskets on my cat since I still need to swap out for e-check.
Old Feb 21, 2010 | 04:30 PM
Pstone's Avatar
Awesome, thanks.
Old Feb 21, 2010 | 05:00 PM
NgoRX8's Avatar
If you ordered new, it will come with the front (header to midpipe) gasket. RB instructions says to reuse the donut gasket off the stock cat.
Old Mar 25, 2011 | 05:44 PM
Nadrealista's Avatar
I just installed mazsport midpipe on mine with stock catback and stock donut is to small..where can I get 3" donut or should I use different gasket?
Old Mar 25, 2011 | 05:49 PM
Jon316G's Avatar
Grasshopper
Like I mentioned in that post you replied to... I use the gaskets from RR, which is the same thing that actually came with the MazSport midpipe when purchased new.
Then I keep the OEM gaskets with my catalytic converter for e-check.
Old Mar 28, 2011 | 08:26 AM
They want $45 plus shipp for those two gaskets..
ended up ordering these from local exhaust specialist:
http://motors.shop.ebay.com/i.html?_...506.m270.l1313
now I need to source some aluminum blocks to make proper spacers for crossmebers..how did you make yours? any pics?
Old Mar 28, 2011 | 06:20 PM
Jon316G's Avatar
Grasshopper
I kept the cross-members off... been that way for several years.
I don't autocross/track my car, so I'm not going to induce much body twisting during everyday driving.
Couple thick stocks of aluminum would be much better than a stack of washers... I always laughed at that concept.
Old Mar 29, 2011 | 07:05 AM
Jon316G's Avatar
Grasshopper
do you know what kind of store would carry aluminum in blocks. I'd rather get it locally.
If you really want to go this route and don't have the supply/tools to DIY, write down the dimensions (length, width, and thickness) for the size block you want and take it to a metal/fabrication shop.
You'll also have to note where the bolts are going to be inserted so they can drill the holes out for you.
Now my opinion (take it or leave it) is that doing this isn't worth the hassle.
Lets just say I have the ability, supply, and tools to make my own blocks... but didn't do it...
Think of this too... my MazSport mid-pipe bottoms-out while going over some speed bumps.
Now imaged what would happen if I hit those same speed bumps with some blocks installed that hung lower than my mid-pipe.
I just want you to think real hard before jumping into this.
cliffkemp
Dec 24, 2024 10:48 AM
airlive
Jun 28, 2020 07:46 AM
mdl0209
May 23, 2019 05:46 PM
Digitz0070
Sep 25, 2015 10:58 PM
DVerdeyen
Sep 13, 2015 11:19 AM
