starting car
Old Feb 19, 2010 | 05:59 PM
mefrono8's Avatar
NFS
Angry starting car
when I start my car it seems like it doesnt want to start it takes so long to start it. Need help finding the problem. its all stock 2004
Old Feb 19, 2010 | 06:03 PM
Charles R. Hill's Avatar
Owner of BHR
1) Does it take even longer to start when it is warmed-up? If your answer is "yes", proceed to #2.
2) Is the car/engine still under the factory warranty? If your answer is "yes", proceed to #3.
3) Register this "concern" with your dealer's service representative and wait for your new engine to be installed.
Old Feb 19, 2010 | 07:12 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
^................ and if number 1 is "No"?
You then think it might be just in need of the updated starter?
Old Feb 19, 2010 | 08:31 PM
or clogged CAT to a lesser degree.
Still need more info on maintence and situation it occurs.
Hard to start when cold are completely differnent solutions.
Old Feb 19, 2010 | 08:39 PM
elysium19's Avatar
How diagnostically/specifically does the only-a-problem-when warm thing point towards a compression issue? Has anyone ever seen that issue point to some other root cause? I'm looking into this issue myself and it might be helpful for people if we can develop a most-likely diagnosis based on presentation....
Typically, hard starting issues are related to outdated coils/plugs, or a weak starter. But if there's a warm/cold issue, then we should starting looking to get a compression test, and assuming engine internals are the most likely issue?
This is good stuff....
Old Feb 19, 2010 | 09:10 PM
mefrono8's Avatar
NFS
The engine warm. If the cat is clogged how do i unclog it?
Old Feb 20, 2010 | 12:52 AM
CrazyJek's Avatar
"I wanna go fast!"
By getting a new one.
Old Feb 20, 2010 | 07:43 AM
Mazurfer's Avatar
^..............If the CAT is really your problem, it has a 80k mile warranty, so take it in.
Old Feb 20, 2010 | 12:49 PM
mefrono8's Avatar
NFS
Dam you good cause I am at 80k miles.
Old Feb 20, 2010 | 01:55 PM
mefrono8's Avatar
NFS
I have no warranty, got the car used.
Old Feb 20, 2010 | 02:07 PM
rodjonathan's Avatar
silent assasin
its a factory warranty so it doesnt matter how you got the car
Old Feb 20, 2010 | 04:27 PM
CyberPitz's Avatar
Huge hole is huge
Starter
Battery
Coils
Plugs
Plug Wires
Cat
Compression
Pretty much the main culprits. Might as well work on those *in that order?* and see which one it is. Obviously if it's compression, and you're at 80k miles, you are in the engine warranty and can get a new one.
Old Feb 20, 2010 | 06:12 PM
Mazurfer's Avatar
Let's explain since the OP believes he has no warranty.
CAT = Factory Warranty for 80k miles. If you are just over it(80k miles), talk with a dealership and they might let you slide a little bit.................if you need one.
Engine Warranty = Factory Warranty for 8 years or 100k miles.
You have both of these!
Old Feb 21, 2010 | 03:57 PM
mefrono8's Avatar
NFS
So no matter what I have warranty on the CAT?
Old Feb 21, 2010 | 07:33 PM
CyberPitz's Avatar
Huge hole is huge
The Engine and Cat are warranted by the factory and transfers to any owner.
Old Feb 21, 2010 | 07:51 PM
mefrono8's Avatar
NFS
So I can just go to a mazda dealer ship and have the CAT replaced?
Old Feb 21, 2010 | 08:00 PM
hughtwg's Avatar
If the CAT is the problem yes. The dealership will want to make their own diagnosis before they swap the CAT for free.
Old Feb 21, 2010 | 09:16 PM
Pico's Avatar
It's Complicated
It's simple now for you
Take the advice that you have gotten here over the past few days with you to the dealer. Stand your ground and make sure they don't try to put something into the repair order that shouldn't be involved with this repair. Cat is a simple fix-- they will run a diagnostic with percentage past/fail. Put on a happy face and see if they will work with you considering that your just out of warranty. -I did see a cat in the for sale forum- dontknow if it's still available.
However, if it comes to them running a compressor test then make sure you got your service records and again stand your ground. search for threads that talk about fail compression and engine replacement-- worse case scenario
dbarber
Jul 25, 2015 01:34 PM
T_Mags
Jul 24, 2015 11:29 AM
Bamaham
Jul 23, 2015 08:08 AM
thedragonrotar
Jul 22, 2015 08:46 PM
Kangarhew
Jul 18, 2015 08:27 PM
