No brake lights ?!?
Old Feb 2, 2010 | 09:18 AM
tasteslikechicken's Avatar
No brake lights ?!?
It appears that my brake lights are completely out. As in, when I step on my brake pedal the rear brake lights remain completely dark. Reverse lights work, as do the running lights, turning lights, etc.
Anyone else ever see this?
-They could both have burned out bulbs, but this is rather unlikely.
-Is there a fuse for just these lights?
-A switch on the brake pedal that is broken?
One complicating factor is that the DSC/ABS lights go on at the first braking, which (as I understand it) is due to corrosion of the connectors behind the front wheels. I haven't heard that this will affect the rear brake lights, though.
Any advice? TIA.
Old Feb 2, 2010 | 10:59 AM
EDZRIDE's Avatar
2005 White GT
Check the fuse and then the switch.
Old Feb 2, 2010 | 11:10 AM
bose's Avatar
Reginald P. Billingsly
It doesn't always mean your speed sensors are corroded. Check out this thread, many people have had a similar problem, myself included. I bet this is your problem as well. Good luck.
https://www.rx8club.com/showthread.p...ight=STOP+fuse
Old Feb 2, 2010 | 01:26 PM
Wow, how did I miss that thread in the many searches I did about the ABS/DSC lights?
Went out, popped the trunk, and noticed that the harness going to the third brake light had broken cleanly through. A trip to NAPA for some 15a fuses and a little electrical tape and I'm back in business. Although I will need to replace or repair the harness to get the third light working again.
Thank you very much!
Old Feb 2, 2010 | 02:23 PM
bose's Avatar
I did the same thing, looked at every thread relating to abs/dsc. Didn't even think about the fuse until after I read everything.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
stickmantijuana
Rotary Swaps
11
Sep 24, 2015 12:47 AM
wayloco
Sep 1, 2015 09:03 PM
