Manual Transmission Problems
Old Jan 29, 2010 | 08:07 PM
Miketf's Avatar
OK,
New problem. First off I have an 04 with around 45k miles on it. The other day after getting into my car I noticed that the transmission was acting sluggish (It did not want to start moving the car until about 4-5k rpm's in first and so on). I did'nt drive it much after that but I kept taking it for test drives in the parking lot and i progressively got worse. Today it is at a dead stop. I can put the car in gear and it dose'nt stall, and no movement for the car at all in any gears. There is brake/clutch fluid. I replaced the spark plugs since a forum on here suggested that as a fix at the beignning since I had flooded it once, but that does not affect this problem. Any suggestions on what may be wrong with it?
Old Jan 29, 2010 | 08:14 PM
You need a new clutch
Old Jan 29, 2010 | 08:18 PM
Miketf's Avatar
Any suggestions on a replacment clutch that wont cost an arm and a leg? I would also like one that will last.
Old Jan 29, 2010 | 08:21 PM
Talk to Charles at BHR or Brice at Race Roots...both forum vendors....They can help you out with that
ed0128
Sep 9, 2015 04:50 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
Octomus
Sep 3, 2015 11:40 AM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
