Driver door wont open
Old Jan 27, 2010 | 08:42 AM
mushkid's Avatar
Smile,It confuses people!
FL Driver door wont open
I just got to work and as i was trying to get out; i noticed my door wouldnt open. i still had the key in the ignition when pulled the door handle, the lock seems to be jammed. is this some sort of security feature? or am i stuck like chuck? i had to escape through the passenger. i read that this had happened to other ppl, and no one says if its mechanical or what?
i dont have my tools to try anything mechanically due to me being at work, i would appreciate any response please.
Old Jan 27, 2010 | 09:00 AM
alnielsen's Avatar
Hello, Blond Star?
Old Jan 27, 2010 | 10:10 AM
mushkid's Avatar
? i dont get it?
Originally Posted by alnielsen
Hello, Blond Star?
Old Jan 27, 2010 | 10:21 AM
alnielsen's Avatar
Sorry, I know you have a problem and asked for help. But, the joke just fit so well. http://www.youtube.com/watch?v=B3UGhRjPry4
Old Jan 27, 2010 | 10:29 AM
expo1's Avatar
He's as bad as Can
Can you open the door from the outside?
Can you lock / unlock the door with the Key, switch on the armrest, latch on the door, key fob?
Is there something stuck in the door like the seatbelt?
Old Jan 27, 2010 | 10:30 AM
The pull rod from the handle to the lock mechanism may have fallen off....
Does it open from the outside? If it does...remove the inner door panel and that will likely be your problem
If that works....roll down your window to get out when you go home
Old Jan 27, 2010 | 10:52 AM
mushkid's Avatar
Negative!!, i tried with the key outside and with the remote and still got the same result. i dont care about pulling the door panel but i just want to make sure that it's not some type of security feater.
Old Jan 27, 2010 | 11:27 AM
expo1's Avatar
He's as bad as Can
Did you try manually unlocking the door via the ****? If that makes the handles work then the issue might be the fuse by the drivers side footwell, fuse #12.
Old Jan 27, 2010 | 12:20 PM
mushkid's Avatar
i didnt check the fuses, but the lock moves when you unlock it. it just wont open; even though it moves normally i also tried manually and the same thing. it feels and sounds like it unlocks but the door wont open
Old Jan 27, 2010 | 01:14 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Look what Dannobre wrote!
"The pull rod from the handle to the lock mechanism may have fallen off."
This rod usually slides into a little plastic holder which is then clipped onto another point(rod). Either the plastic busted, it popped out of it's holder, or the piece that clips onto the other point/rod popped off.
Old Jan 27, 2010 | 02:27 PM
Your not in Minnesota where it's freezing cold and the rain frooze the locking mechanism ... are you?
Old Jan 27, 2010 | 02:37 PM
Mazurfer's Avatar
^................If I remember right......he's in South Florida, so no chance of that Razz!
Old Jan 27, 2010 | 06:18 PM
mushkid's Avatar
so after closer inspection me and my father noticed scratches by the door and window frame
so most logical conclusion..... someone tried breaking into my car
2 weeks ago someone broke the window in my mx6 and stole my radio.
now i have no way of opening the door, it seems that they broke the lever to open the door
Old Jan 27, 2010 | 06:38 PM
If you have a Slim Jim tool...the door can be opened..might want to get a tow truck driver or a locksmith that does it for a living to open the door
Likely they knocked the rod off the actuator lever....
Old Jan 28, 2010 | 12:38 PM
mushkid's Avatar
so how do i get the door opened?i tried by pulling the cords from the little latch inside the door componet and i cant get it opened.
Old Jan 29, 2010 | 07:57 AM
mushkid's Avatar
guys?? i really cant open the door no matter what??
Old Jan 29, 2010 | 09:15 AM
You need to get someone with the proper tool that can open the door......like I said..try a tow truck driver or a locksmith....you need a wedge and a proper tool to trip the latch..especially since some dim wit tried to do it and likely broke the catch off...
Old Jan 29, 2010 | 01:46 PM
mushkid's Avatar
FL
how much do you think that it will cost me for a locksmith?
Old Jan 29, 2010 | 01:51 PM
Last time My wife locked her keys in the car it cost her $35 for them to open the door....
This might be a PIA to open so likely a bit more....
Old Jan 29, 2010 | 07:39 PM
Mazurfer's Avatar
How much is it worth to you not to climb through the passenger side for the next six months or longer?
Either use google or the phonebook and call a few to see what they say. Yeah......about $35.00 sounds good. Seems like last time I heard of someone needing one that was about the price.
Old Jan 30, 2010 | 07:58 AM
mushkid's Avatar
im going to locksmiths today and mazda to see how much they charge
Old Jan 30, 2010 | 02:00 PM
mushkid's Avatar
So they quoted 120, I took her to the shop after 3 hours of them trying open the door; no success they told to take it to Mazda or call my insurance. I already made a police report
another option I was thinking was just to rip the panel and open it
Old Jan 30, 2010 | 02:01 PM
mushkid's Avatar
Old Feb 7, 2010 | 10:40 AM
mushkid's Avatar
so i got it open, turns out the whole actuator is totally effed!!!! so i need a whole new door lock system, anyone know where i can get one? it for the driver door
Old Feb 7, 2010 | 10:46 AM
Lots of parting out threads..
.Vyndictive comes to mind right now...there were a few others in the last day or so popping up as well
Patrick ( G3tR3DDY2GR3DDY) likely would have the parts as well as Mazmart....
