2009/2010 AT: What's the actual max rpm?
Old Jan 26, 2010 | 07:50 PM
nsu's Avatar
nsu
I know the spec says 7500rpm for AT. Will the car let you get some more revs or it will do the shifting for you at 7500rpm no matter what even if you are on manual mode or the rev limiter is capped at 7500rpm? Thanks!
Old Jan 26, 2010 | 08:28 PM
Bigbacon's Avatar
2006 WB AT
if you are in manual mode it will just hit the rev limit, beep, and back off and just keep doing that until you switch gears up or lay off the gas. Manual mode will never switch up for you, it will only switch down for you..
if you are not in manumatic mode you'll probably never get it to hit the limit. it will switch on its own well before 7500
Old Feb 9, 2010 | 09:25 PM
Onyx57's Avatar
there is supposed to be a chip that overrides the limiter, can rev past 9500.
Old Feb 24, 2010 | 08:43 PM
nsu's Avatar
nsu
Is the chip detectable by the dealer at service and void your warranty?
Old Feb 24, 2010 | 09:45 PM
JinDesu's Avatar
went back to srsly broke
I...don't think there is this chip for the 09/10 models. There was this "chip" for the 08s and olders, but there wasn't a point since we have the AP.
@BigBacon - are you sure it won't shift up? I'm pretty sure if you hit the limiter for some time, it'll shift up. I'm just not one to hit the limiter.
Old Feb 28, 2010 | 12:52 PM
freaklinkmusic's Avatar
yeah cobb ap will do it. should be coming out for the 2009-2010 rx8 sometime soon. I changed my rev limit to 9300 and it shifts smooth as butter.
http://www.youtube.com/watch?v=E6UMb...layer_embedded
Old Mar 1, 2010 | 07:13 AM
PeteInLongBeach's Avatar
Isn't the VDI non-operative / deleted on the A/T motors, since it would open just slightly before the stock A/T redline? If this is the case, I would think raising the redline on the A/T would not have quite the same effect as the M/T (other A/T dynamics aside).
Old Mar 1, 2010 | 01:12 PM
the 6port autos have exactly the same powerplant as the M/T; 2006-present. 2004 and 2005 automatics have the 4 port engine so I have no idea, ive ever dealt with one of those, maybe someone else could answer that.
but the apv,ssv, and vdi all open on my engine at the same time as the m/t engine
Old Mar 1, 2010 | 02:34 PM
JinDesu's Avatar
Why do you say this? The last valve opens at 7250rpm on the 6AT and 6MT.
Old Mar 1, 2010 | 08:45 PM
Yes, the vdi would open at 7250, and the a/t redline is 7500, so what would be the point in even having that functionality on the a/t? That's why I'm wondering if it's on the a/t motors at all. Would this be part of the a/t motor de-tuning, or is it just the redline reduction?
Old Mar 3, 2010 | 10:11 AM
yes the vdi is there on the 6speed at. & the real stock redline for the AT's is about 7800 rpm. however if you have ap you can open it earlier, or later(probably wont help with power. Or you can just raise the rev limit like me!
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
Steve Dallas
RX-8 Racing
10
Oct 7, 2015 10:30 AM
Hiroshima_RX
Sep 21, 2015 06:28 PM
