Injector swap AP, double check my math and method please?
Old Jan 24, 2010 | 04:05 AM
Mawnee's Avatar
I divide by zero
Ok, just got done installing my 900cc injectors in my P2s(middle 2 on the big rail).
I think the math is (900/380)*476
Which gives me 1127.4 as my new value for the Injector size setting?
Also just to make sure...... does this change go in "Bank 2 Injector size" or Bank 3?
I always prefer to ask the stupid question for confirmation than just go for it and do harm.
Old Jan 24, 2010 | 07:32 PM
05rex8's Avatar
sold the 8... :(
it should be (900/390)*476
which is 1098.4615
so put in 1098 in bank 3 injector size
BTW you are going to have to start over with tuning most likely. MAF scale and injector scale need to be spot on...if not the injector duty cycles may still be high as well as running wicked rich or even lean for that matter.
Old Jan 24, 2010 | 09:59 PM
Mawnee's Avatar
I divide by zero
Thanks for the info
Now to go rip the manifold off again.... Something is leaking BAD when I turn the key on and it tried to pressurize the fuel line
Gawd I miss changing injectors on an LS1....10 minute job.
Old Jan 25, 2010 | 04:44 AM
Mawnee's Avatar
I divide by zero
That was an easy fix, the rearmost Injector was somehow missing the top o-ring. Car started up fine and doesnt appear to be leaking anymore. Parked it outside, I'll leave it alone for a day or so to let all the gas evaporate off the engine before I drive it anywhere.
On the injector size, I keep finding it listed as 380 AND 390 everywhere. So I just split the difference and set it at 1115 for now. So its only 1.3% off regardless which is correct
-EDIT ...uhga! no..the leak isnt fixed. Just went out and started the car...leaking all over the damn place. Pulled it back in the garage. Is there some secret to seating our injectors I"m not aware of?
Old Jan 25, 2010 | 09:33 AM
olddragger's Avatar
check the fuel line that feeds the two injectors up top---it can go bad---it is recommended not to reuse it. I would get a new one---ask me how I know?
OD
Old Jan 25, 2010 | 11:21 AM
Mawnee's Avatar
I divide by zero
OD
Thanks for the advice OD
You know, I havent touched it yet because I"m so frustrated with it....but that is exactly what I've been dreading it is...
Let me guess, mazda dealer only item? They have to order them from over seas via Mars and it costs roughly 13 times more than it should?
Old Jan 25, 2010 | 11:26 AM
05rex8's Avatar
sold the 8... :(
Make sure that you lube the o rings. If you don't they could tear when you seat them. Also it makes it easier to attach them to the fuel rail. I used some mmo lol. They slid right in.....
Old Jan 25, 2010 | 11:32 AM
Mawnee's Avatar
I divide by zero
I always just pull the dipstick for a convenient o-ring lube source
Old Jan 25, 2010 | 12:41 PM
Kane's Avatar
Senior Member
In the factory manual the injectors have an operating range - but from my flow tested secondaries and the middle of the road readings from the FSM; 380cc/min is as close to a definitive answer as I have ever found.
Old Jan 25, 2010 | 12:45 PM
05rex8's Avatar
sold the 8... :(
hahaha nice
Old Jan 26, 2010 | 12:49 AM
PhantomRX-8's Avatar
Bad Ass
which is 1098.4615
Damn it. I edited the Bank 2 slot instead of Bank 3. Guess Im starting over! I had commented on the Cobb forums like 2 months ago and no one replied.
Old Jan 26, 2010 | 01:54 AM
Mawnee's Avatar
I divide by zero
Yep, I saw your post over there. I searched for a couple of hours for an answer before I posted here
Old Jan 26, 2010 | 01:59 AM
Bad Ass
Lol!! Same here. I thought it was too basic of a question and didnt want to deal with everyone saying., "SEARCH"!!! I also figured it was in the Cobb discussion thread but never finished going through the 200+ pages!
Old Jan 26, 2010 | 02:27 PM
Mawnee's Avatar
I divide by zero
Its fixed and seems to be running right, posting the details in my build thread since this had gotten kinda of topic for the tune section
Jesus Martinez
72
Jul 26, 2023 11:29 PM
04Green
12
May 13, 2023 10:08 PM
wankelbolt
Sep 9, 2015 03:43 PM
harithac
Aug 26, 2015 09:24 AM
dbarber
Jul 25, 2015 01:34 PM
