How to install B Pillar Applique
Old Jan 24, 2010 | 01:29 AM
Iceman808's Avatar
Hi all
I have the original factory B pillar kit. Unfortunately the instructions are in Japanese.
Can anyone help on this one. I gather I need to use a hairdryer at some stage.
My appliques have the adhesive already on them (there like a giant sticker)
Cheers
][ce
Old Jan 24, 2010 | 03:29 AM
Twiztog43's Avatar
dont you just stick them on?
Old Jan 24, 2010 | 03:34 AM
ZumnRx8's Avatar
RX8 & RX7 owner
lol... googl3 is ur friend
Old Jan 24, 2010 | 03:43 AM
Twiztog43's Avatar
"Installation is very easy requiring only a thorough cleaning of your existing b-pillars and a peel 'n stick application of the appliqués. "
Old Jan 24, 2010 | 11:10 AM
NgoRX8's Avatar
there's really only one way you can mess up.
if you don't line it up correctly...
but if you must know
line it up and peel from a top corner, peel and fold it slanted so you have the applique flat against the pillar with the paper backing sticking out. should only have a bit of adhesive exposed so you can line up the top. keep your hand sliding down the applique as you pull the backing in the same fashion. this will keep it aligned and flat.
Old Jan 25, 2010 | 01:55 AM
Iceman808's Avatar
Thanks for the feedback
I guess it's just peel and stick. The manual showed a hairdryer and another contact sheet that goes on first. Perhaps it relates to an older type of applique.
Thought maybe you heat up the panel before you stick it on.
Cheers
Old Jan 25, 2010 | 02:04 AM
NgoRX8's Avatar
using a hairdryer will make the adhesive stick better, in a sense.
Old Jan 25, 2010 | 02:51 AM
onyx8's Avatar
yeah just keep test-fitting them and eyeball just about how precise you want each edge of the applique to be in relation to the edges of the b-pillar..Because once you start, it really doesnt want to come off.
crimson809
Aug 14, 2016 10:03 PM
Zube6115
Sep 30, 2015 12:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
