Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
check engine light?
Old Jan 19, 2010 | 10:04 PM
Juan09's Avatar
Question check engine light?
i just installed a rb revi intake and my check engine light came on after a couple minutes of running it. Is this normal? should i take it in for a diognostic?
Old Jan 19, 2010 | 10:38 PM
autotragic rx8's Avatar
ive done some mods that cause my CE light to come on....but it usually goes away after a couple of cycles. if it doesnt....then ya...get it checked out
Old Jan 19, 2010 | 10:47 PM
Juan09's Avatar
cool thanks man, and what mods did you do to set it off?
Old Jan 20, 2010 | 08:49 AM
Riley Craven's Avatar
Autozone will check and read the code for you for free. They cant reset it, but at least you will know if the issue is serious or not.
Old Feb 3, 2010 | 12:54 PM
quicksilver34's Avatar
LIFE IS GREAT
Mine is on cuz of high flow cat
Old Feb 3, 2010 | 12:57 PM
Just do the brake stomp or disconnect the battery for ten minutes.
If it comes back... then check the cap on the TB. Make sure it did not fall off or is cracked.
Also check to make sure everything is tight.
Old Feb 3, 2010 | 01:23 PM
LIFE IS GREAT
What a t b?
Old Feb 3, 2010 | 01:26 PM
Get with me whenever dude, I have a couple of code readers. Come to think of it, get with the "other Juan" he has one of mine right now. But likely if everything as installed correctly then it will correct itself.
Old Feb 3, 2010 | 02:06 PM
LIFE IS GREAT
I live like four hours from u.. to do the codes
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
