Acceleration issue
Old Jan 19, 2010 | 06:34 PM
rx78840's Avatar
Rx78840
Acceleration issue
It's been about 2 months now with my 04 rx8 mt with 46k miles stock. Just this week i noticed when im accelerating hard from first to second gear around 8k rpm's my car seems to choke, then proceeds after that it still seems to struggle getting up to high rpm's.... It's really noticeable so I'm pretty worried it could be something bad...Any ideas?
Old Jan 19, 2010 | 07:23 PM
Tweek's Avatar
RobotsToRobots.com
What do you mean by choke? kind of hard to tell without seeing it
Old Jan 19, 2010 | 07:26 PM
rx78840's Avatar
Rx78840
well it is hard to explain it.... it stops accelerating for a split second when it hits about 8k rpm's. but then resumes.
Old Jan 19, 2010 | 07:35 PM
rotarykillz's Avatar
Rotary Freak
plugs/coils/wires/air filter
don't start worrying until you've checked all those first.
Old Jan 19, 2010 | 07:51 PM
rx78840's Avatar
Rx78840
Got you... i've been saving up for those... im 99.9 percent sure last owner didn't care about the car and its needs...
Old Jan 19, 2010 | 07:55 PM
invasion08's Avatar
If the coils and spark plugs have not been changed yet i would start there. I would change the ignition coils, spark plugs, and spark plug wires. Dont worry anyway The cat converter is covered for 8yr 80k miles and the engine is cover for 8yr 100k miles
Old Jan 19, 2010 | 07:59 PM
invasion08's Avatar
Depending on your budget i recommend BHR Ignition Kit http://blackhaloracing.com/products-...tion-system15/ $557 w/spark plugs. The oem coils have been know to fail
Old Jan 19, 2010 | 10:49 PM
Pico's Avatar
It's Complicated
Sounds like your cat is going.
Are you getting a blinking CEL while accelerating or in 6th under full load? If you then you got a misfire --- plugs/coils/could do the wires to
Old Jan 20, 2010 | 08:09 AM
rx78840's Avatar
Rx78840
Nope no CEL
Old Jan 21, 2010 | 03:17 PM
MTspeeds1's Avatar
Im kinda having the same problem, ever since I changed my air filter it seems like my car isn't accelerating as fast as it used to
Old Jan 21, 2010 | 09:49 PM
Pico's Avatar
It's Complicated
How hard are you running the car when happens?
It could be the begin of a CAT failure or clutch slippage from heat generated while running hard
Old Jan 21, 2010 | 09:56 PM
MTspeeds1's Avatar
for me it feels like my car is dragging even from 1000 to 4000 rpm
Old Jan 22, 2010 | 08:19 AM
Pico's Avatar
It's Complicated
^ I think your feeling the lack of torque in the bottom part of the power band. The car is a dog til about 5500 rpm
Old Feb 6, 2012 | 01:16 PM
GRrx8's Avatar
im having the same problem but 05 shinka plugs wires n coils rnt bad but its a slight hesitation n 1st going to second got new fuel pump on the way hopefully it fixes it if not then its $100 on new plugs
Old Feb 6, 2012 | 01:27 PM
GRrx8's Avatar
im also having another problem with my 8..... about 5 months ago blew the internal gaskets got them replaced along with the externals shop installed motor n cranked it up but then the idle started to bog up n down n then itll shut off i have to keep the idle up wen ever i come to a stop otherwise the car will bog and shut off, and i am ******* tired of having to do that cus its wasting alot of gas having to keep the idle up..... the shop ran a vacum test passed then a injector test passed too then scaned it said plugs changed em out still did the same thing changed the air filter out n fixed it for about a day n half but then started doing it again looked everywhere on the web about the problem friend said egr valve but dont have one on the 8, another friend said it could b the fuel filter so i bought the whole pump assembly so hopefully its that, web also said it could b the baro pressure sensor but idk gotta wait till the pump is in do yo9u guys have any input on wat the problem could be
Old Feb 6, 2012 | 02:11 PM
zoom44's Avatar
you had your engine rebuilt and it hasnt run right since?
Old Feb 7, 2012 | 07:18 AM
GRrx8's Avatar
yup its been that way since its been rebuilt
Old Feb 7, 2012 | 08:30 AM
bladeiai's Avatar
Plus One...
What did the people that rebuilt it say when you asked them about it?
Old Feb 7, 2012 | 01:03 PM
GRrx8's Avatar
they scanned it and it said something about the map n something else but i dont remember but i replaced the map and the **** still did the same thing
Old Feb 7, 2012 | 01:44 PM
200.mph's Avatar
FULLY SEMI AUTOMATIC
who built it? i would not be happy. what parts did they replace?
Old Feb 7, 2012 | 05:25 PM
zoom44's Avatar
what map?
Old Feb 8, 2012 | 01:40 PM
GRrx8's Avatar
this lil mom and pop shop by my place. my bad i meant mas. if you read my post it said internal and external gaskets and plugs
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
Randolph Alvarez
May 30, 2016 01:08 AM
ed0128
Sep 9, 2015 04:50 PM
tgaffner
Sep 7, 2015 08:49 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
