Racing fuel in the rx8
Old Jan 17, 2010 | 11:44 AM
EdwardLenczowski's Avatar
NY Racing fuel in the rx8
Ive always used 93 octane in my 8 but i was wondering how racing fuel prob 100 octane will alter performance... Im just curious because its a rotary... Has anybody tried this? And what were the results?
Old Jan 17, 2010 | 12:14 PM
Chad D.'s Avatar
Spinnnnnnnnnnn
I would also like to know. I sometimes fill up at the airport.
Old Jan 17, 2010 | 12:20 PM
expo1's Avatar
He's as bad as Can
It will do nothing unless you change the tune of your car with a device such as the access port. If you use leaded race gas you will make things worse.
Old Jan 17, 2010 | 12:26 PM
invasion08's Avatar
It will make your wallet lighter which will make you lighter which makes the car lighter which = faster 0-60 times.
Old Jan 17, 2010 | 12:31 PM
JinDesu's Avatar
went back to srsly broke
Not if you use a credit card!
Old Jan 17, 2010 | 01:25 PM
arghx7's Avatar
if anything it will lose power (although probably not enough to notice). the ignition timing curves are not optimized for that much octane.
Old Jan 17, 2010 | 05:10 PM
Now Im talking about mixing race fuel with 93... 100 octane would certainly not work well but 95 or 97 might not be too bad and im buying an access port
Old Jan 17, 2010 | 05:57 PM
invasion08's Avatar
Stick with 93 octane.
Old Jan 17, 2010 | 09:01 PM
dieselsdad's Avatar
First of all, avgas and gasoline designed for street use have their octane ratings figured in different ways. So the octane numbers are not comparable.
Secondly, oil mixed with gas LOWERS the octane rating. Think about that one.
Old Jan 20, 2010 | 09:38 AM
^^ ding, ding, ding
and depending on how well your engine holds compression ...
Old Jan 23, 2010 | 04:16 AM
Avalanx's Avatar
The RX8 is optimized for 95 Octane...
Filling up with leaded fuel could also harm your engine...
Stick to unleaded 95 if you can
Old Jan 23, 2010 | 07:19 AM
CRO8TIA's Avatar
Leaded fuel will destroy your cat.
Old Jan 23, 2010 | 07:46 AM
Spin9k's Avatar
Momentum Keeps Me Going
Octane rating of a fuel does not equal energy content of the fuel, rather it is a measure of the fuel's tendency to burn in a controlled manner. Higher octane ratings does equal higher activation energies (energy input to start a chemical reaction), not increased energy in the fuel.
Switching to a higher octane fuel does not, in and of itself, add any more hydrocarbon content or oxygen, so the engine cannot produce more power. In fact, the substance used to increase octane generally reduces the energy content per unit of fuel.
Lead used in fuel currently is mostly for aviation gasoline, so not a good choice for cat equiped engines.
Old Jan 23, 2010 | 07:57 AM
StealthTL's Avatar
Metatron
Even if you're catless, the lead will eventually destroy your Primary O2 sensor.
Then your car won't run and you'll find out how much they cost......
The un-turboed US engine is just fine at 91 (95 on the Japan/Europe scale)
Old Jan 23, 2010 | 10:07 AM
zoom44's Avatar
this ^ and what team and stealth said are what you need to know. I suggest reading other octane discussions that include posts and links from me.
thread closed
8is>enuff
Sep 24, 2015 08:57 AM
Modified Dave
Sep 19, 2015 08:58 PM
harithac
Jul 31, 2015 09:57 PM
AussieGray
Jul 16, 2015 03:58 AM
