Whats so good about Carbon Fiber Clutch?
Old Jan 15, 2010 | 03:17 PM
This question just came out of nowhere inside my brain so ...
yeah, whats so good about Carbon Fiber Clutch ? Like Exedy's Twin plate.
All I know is that they are very durable and can withstand almost #$32804012384 Heat.
and bad thing is the cost.
Anything else? How does the pedal feel? Anybody know ?
Old Jan 15, 2010 | 03:22 PM
Had one on a R32....the thing was great when it was warm.....kinda stupid cold...you had to slip it to warm it up....after that it was bullet proof
They are very light...and strong...but abused they can break....
Very pricey.....not sure they are an advantage over a light carbon kevlar/metal PP combo for a real world application
Old Jan 15, 2010 | 07:49 PM
ASH8's Avatar
Super Moderator
Dan, what (wondering) does the CF Clutch Plate do to the Fly Wheel and or Pressure Plate?..any marks or scorching??
I guess you renew the PP at the same time?
Old Jan 16, 2010 | 07:59 PM
PhillipM's Avatar
They're pretty much ideal for a clutch:
1) They're very light
2) They've got a very good friction co-effiecent, so you can use a fairly soft spring = light pedal
3) They have a lot of internal damping so they engage as smoothly as an OEM organic clutch
4) Because they contain solid lubricants as part of their makeup, they're pretty light on the flywheel facing too.
5) They can take so much heat that the aluminium clutch basket overheats before the clutch does.
6) Because the friction bond is more chemical than mechanical based, wear rates are fairly good too.
Old Jan 16, 2010 | 08:06 PM
ASH8's Avatar
Super Moderator
Thanks Phillip...any idea on price or cost...roughly?
Old Jan 16, 2010 | 09:29 PM
True Carbon to carbon clutches are really pricey $4k AND WAY UP...there are ones like the Carbonetics and Exedy that are below $3k....
Old Jan 16, 2010 | 10:35 PM
they handle the heat and wear better, carbon-carbon is not the same as carbon fiber, carbon-carbon is what they use on the nose cone of ballistic missiles to handle the atmospheric re-entry heat and provide better accuracy, it's much more expensive due to the manufacturing complexities but handles the heat and wear of a small diameter multi-disc racing clutch better than anything else
Old Jan 16, 2010 | 11:58 PM
Thx for all the information guys
Ok, so does that mean :
- Its the same if not lighter than clutch pedal feel (depends on who make them? material?)
- It probably last forever, it should last longer than typical Stock/Organic at least?
- Its pretty easy on Flywheel surface
- Its going to be expensive.
correct ?
Speaking of Carbonetic, I knew that brand from a Magazine, they have Single, Twin, and Triple C/C (Carbon Carbon like Team said?) clutches for RX-8. Anybody use Carbonetic stuff before ? good stuff ?
Old Jan 17, 2010 | 12:07 AM
I would get the BHR aluminum PP clutch, plus you get to choose between the cherry and grape koolaid flavors
that's a j/k, BHR will set you up
Old Jan 17, 2010 | 12:45 AM
Charles R. Hill's Avatar
Owner of BHR
Originally Posted by TeamRX8
...... plus you get to choose between the cherry and grape koolaid flavors
That reminds me that I gotta stock up on those flavors since we include them in every purchase.
Old Jan 17, 2010 | 01:12 AM
Flashwing's Avatar
3-wheeler
BHR Koolaid!!
Old Jan 17, 2010 | 01:16 AM
hoss -05's Avatar
Lucky #33
lol O yeah~! How many different single plate kits are there out there?
Old Jan 17, 2010 | 01:41 AM
@!!narotordo's Avatar
FLAME ON!
Old Jan 17, 2010 | 08:51 AM
wtf lol
hmm ... clutch ... hmm ... carbon ... hmm ...
Old Jan 17, 2010 | 10:03 AM
PhillipM's Avatar
The last one we used was ~£2850.....or roughly $5k AUD
Old Jan 18, 2010 | 03:33 AM
kersh4w's Avatar
Hit & Run Magnet
rough.
Old Jan 18, 2010 | 04:20 AM
FLAME ON!
Dude I can buy another rx8 with that lol
Old Jan 18, 2010 | 11:11 AM
PhillipM's Avatar
It was for a rally car though, they pay for themselves over time in that kind of use.
Old Jan 15, 2011 | 09:57 AM
hoss -05's Avatar
Lucky #33
The Carbonetic unit is on the way now. Should be installed in the next few weeks. Ill let you know how I like it.
Old Jan 15, 2011 | 10:25 AM
holy mother thread resurrection !
well, let us know how it goes
Old Jan 15, 2011 | 10:50 AM
hoss -05's Avatar
Lucky #33
Will do! I will be the first one I know of running this clutch. It was not as much $$ as I expected and comes with a lightweight flywheel as well.
The flywheel is 9.9 lbs with a total weight of just 20.1 lbs for the whole kit. It should add some zoom zoom.
drebbrnator
Dec 27, 2018 07:02 PM
Dokuji
Nov 1, 2016 02:51 PM
BigMikeATL
May 26, 2016 12:31 AM
EfrainOlivares
Aug 14, 2015 06:17 PM
