West RX-8 Forum Serving CA, NV, AZ, HI
Coolant warning light on and off
Old Jan 11, 2010 | 10:46 AM
ChesteRx8's Avatar
Hi. how are you fellow 8 friends! i have a question.. Once in a while my coolant warning light would come on and off... but when i look at my temp gauge seems to be fine.. its that light keep going on and off everrytime i use my paddle shifter or going 70 mph and over.. How do i solve this kind of problem? thanks!
Old Jan 11, 2010 | 10:48 AM
NgoRX8's Avatar
the sensor in the tank is bad.
either replace the entire tank or unplug it and check regularly.
Old Jan 11, 2010 | 10:56 AM
ChesteRx8's Avatar
how much is it if i take it to the dealership? any idea?
Old Jan 11, 2010 | 10:57 AM
ChesteRx8's Avatar
is this something i should freak out about?? i dont want my 8 to overheat or something
Old Jan 11, 2010 | 11:02 AM
J03K1LLARX8's Avatar
ジョーイ
Its a faulty censor. It hapeneds to all the 04s I just ignore it now but check my water level every fill up.
Old Jan 11, 2010 | 11:06 AM
ジョーイ
The stealership is going to charge you about 200+ to change it. I say just live with it like the rest of us do. Just check it every fill up and you'll be good.
Old Jan 11, 2010 | 05:03 PM
RufusVonStorm's Avatar
My car used to do that, but only when pulling ahead around the top part of 4th gear- strange
Old Jan 11, 2010 | 05:11 PM
The Reverend's Avatar
That's a lie
This was happening to me earlier in the summer. I put a bottle of Water Wetter in the tank and since have been vigilant with checking the level. It has not come back since then, and I used to get the light everytime I was above 4500rpms for more than 10 seconds
Old Jan 13, 2010 | 10:24 AM
ChesteRx8's Avatar
how often i should check my coolant? everytime i get an oil change?
Old Jan 14, 2010 | 01:41 AM
volcomx31's Avatar
Silver Power
once a week
Old Jan 14, 2010 | 07:04 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
Check it once a week or every time you check your oil. But something tells me you aren't doing that very regularly either are you?
You can actually take the tank out itself and flush it out real good and you will be okay. All the experiments I did indicate that it's the crud in the bottom of the tank that keeps the magnetic float from doing it job.
If you really wanna read all about it, go here..............but know that I went way far with this thread.
https://www.rx8club.com/showthread.p...ottle+revealed
Old Jan 14, 2010 | 11:59 AM
Kingsfan's Avatar
PS - ducks suck
the light used to make me nervous, but i check the level all the time and it's been fine. now i just ignore it. good info in that thread!
Old Jan 15, 2010 | 02:44 AM
ChesteRx8's Avatar
well so im going to take it to dealership and let them flush it for me.. i hope they wont charge me alot!!
Old Jan 15, 2010 | 02:53 AM
mike[piston eater]'s Avatar
O' Let's do it.
haha my light used to go on an off back in the day, now its just permenantly on along with cel and sometimes airbag light wich i think is due to my rediculous bass
Old Jan 15, 2010 | 12:11 PM
VTR_RX8's Avatar
I disconnected the coolant level switch and the light indicator does not come on any more. Thanks Guys!!!
Question: Does that switch run in series with another switch or sensor? Will disconnecting the coolant sensor prevent any other sensor related to this light indication on the dash? Is the red light just below the Oil pressure gauge only for indication of the coolant level or is that light for other sensors?
Old Jan 15, 2010 | 02:46 PM
UrbanOcho's Avatar
Stick Specialist
hey good to see everybody from the coolant false alarm alumni club again
Old Jan 15, 2010 | 03:07 PM
lesper4's Avatar
T-29 years and counting
mine does it too from time to time, just keep checking the temp and the coolent level.
Old Jan 18, 2010 | 02:07 PM
ChesteRx8's Avatar
ok i just went to the dealership today and i GOT omfgbbqrofl owned. I had an oil change and of course it was around 49 bucks. and then i asked to check my coolant cuz i told em my situation and guess what! they want to charge me 300 bucks or something to fix it. i was like aight well **** it. just check my coolant level.. and if you can just fill it up or something if it needs to. and then they charged me 47 bucks for that. so my total came up to 80 bucks. still.. i felt neglected..
Old Jan 18, 2010 | 02:19 PM
Alexb's Avatar
desperately needs a drop
This happened to me in the summer.... only when I was at 4K+ for a while.
I just added coolant...
Azki23
Jun 27, 2018 03:48 PM
erikcamacho15
Sep 12, 2015 11:23 AM
Irvinb16
Sep 11, 2015 10:27 PM
