Big problem guys.. need your help (Ignition coil bolt)
Old Jan 11, 2010 | 03:33 AM
WikkedOne's Avatar
Deals on wheels
TN Big problem guys.. need your help (Ignition coil bolt)
Recently I noticed that when I revved my 05 AT to redline i got a loss of power and a flashing cell around 6k.. so I searched on here and found that I probably needed to replace my ignition coils
I read up on the DIYs and everything and everything was going pretty good until we were tightening the bolt onto the last one -- The bolt snapped off right where it tightens to on the coil.
after some debate we decided the only way we could really get my car back on the road at least for temporary was to drill down part of the ignition coil where the bolt feeds through so we could still use what little bit of bolt nub was left to hold it in place until i could replace the plate thing with the bolt in it.
so basically my question is - what is the name of the part the ignition coils bolt onto - and do you think it would be that hard to replace.? it didn't look like it would be that hard, but I just have no idea what it is called or where I can get one.. any ideas?
Old Jan 11, 2010 | 03:37 AM
kersh4w's Avatar
Hit & Run Magnet
i snapped one of the bolts off too. heh, luckily there was still enough to get a bolt on there though.
you could just drill through the plate and put a bolt through both the plate and the coil.
Old Jan 11, 2010 | 03:41 AM
Jon316G's Avatar
Grasshopper
Just remove the plate, drill a hole (like kersh4w mentioned), and add a bolt.
Old Jan 11, 2010 | 02:47 PM
WikkedOne's Avatar
Deals on wheels
Yeah, that was the other option... but we didn't want to remove the plate last night, and we decided that if I was going to remove the plate, I would do it the right way and just replace it completely... do anybody know what it's called or where I can get one?
Old Jan 11, 2010 | 03:27 PM
hakuna matata!
mazda part # N3H1-18-105
about 25 bux from onlinemazdaparts.com
you might want to inquire if the bolts come with that.
Old Jan 11, 2010 | 03:29 PM
WikkedOne's Avatar
Deals on wheels
got it, thanks man
ironj221
36
Jan 20, 2026 08:28 PM
05TR1CH
Apr 18, 2023 04:56 AM
delicious_dallan
Jan 17, 2020 09:17 AM
cschoeps
Aug 6, 2015 12:44 PM
madrotor
Jul 26, 2015 12:06 PM
