New Plugs - old problem? Hot start
Old Jan 8, 2010 | 08:55 PM
rXter's Avatar
04 - 45K miles.
In 05 I had the dreaded hot start stall. Mazda put a new batt and different plugs in it. SOlved teh problem. Now I am getting ready to change the plugs, wires, coils.
Can I use the standard NGK plug set or do I need the "hot start" leading plugs (which are $42 each)?
http://www.mazdatrix.com/8ignition.htm
Thanks gents.
Old Jan 9, 2010 | 07:32 AM
rXter's Avatar
Bump
Old Jan 9, 2010 | 10:11 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
You should be able to use the standard NGK plugs.
RE7C-L
RE9B-T
Anybody esle?
Old Jan 9, 2010 | 12:46 PM
Old Rotor's Avatar
Originally Posted by rXter
04 - 45K miles.
Thanks gents.
Yes the stock NGK's are the best for stock engines. So are you having hot start problems again too? Do you have the new level starter? Have you tried to decarbon your engine?
Old Jan 9, 2010 | 01:43 PM
johny lucas's Avatar
what is the best way to decarbon your engine ?
Old Jan 9, 2010 | 02:16 PM
Mazurfer's Avatar
Lucas................Use Seafoam or the Mazda cleaner.........if it needs it.
Do a search on "SeaFoam" and threads will come up.
This will give you some insight!
http://www.finishlineperformance.com...4-08-1924g.pdf
And here is the Mazda cleaner.
http://www.finishlineperformance.com...cat=338&page=1
If you are having hard starts and you are an 04, then you really need to see if you have the upgraded starter.....assuming battery has been all checked out and is good.
See the threads at the bottom of this page now for other info relating to hard starts, if that's what you have.
SUKIEE
Oct 9, 2017 09:41 PM
RayBarron
Oct 19, 2015 08:08 PM
robd1337
Jul 31, 2015 09:35 PM
madrotor
Jul 26, 2015 12:06 PM
dbarber
Jul 25, 2015 01:34 PM
