Pls help me to understand something about exhausts
Old Jan 8, 2010 | 10:17 AM
Harvis's Avatar
Hi all , sorry for my english i dont understand a lot.
but im litttle confuse about the order pls tell me order if its correct.
Header-Catalityc- Midpipe - cat back
And more confused when here people talking about midpipie
dont know if it referring to the cat or to the other pipe plugged to the catback
Old Jan 8, 2010 | 10:42 AM
Snrub's Avatar
Header-Catalytic-catback
Typically a mid-pipe refers to a catalytic converter replacement pipe. It's either a straight pipe or a "resonated mid-pipe" which means it has a small high-flow muffler to keep the noise down (cats also reduce noise).
Old Jan 8, 2010 | 10:52 AM
dozer's Avatar
on his 3rd rx8
^that
Header - Catalytic Converter(or midpipe) - catback
Old Jan 8, 2010 | 12:20 PM
Jon316G's Avatar
Grasshopper
Depends on how "technical" you want to be.
In the pic above, the order is:
Header -> Catalytic Converter -> Middle Pipe -> Silencer/Muffler
#4 in the diagram is considered the Middle Pipe.
But we commonly combine the Middle Pipe and the Muffler together and call it a cat-back because its the piping behind the catalytic converter.
That then gives you three sections:
Header -> Catalytic Converter (or now mid-pipe since its in the middle) -> Cat-Back
arexatemate
Oct 28, 2019 08:16 AM
fc2se
NE For Sale/Wanted
Jun 1, 2016 08:55 PM
