Check Engine Light - CEL
Old Jan 6, 2010 | 10:00 PM
Iceman808's Avatar
HeHe
I removed one of my fuses (in foot well, passenger side) to check the type so I can buy some spares. It was the interior room light fuse (15A)
I then turned the engine on and got a check engine light for the very first time.
I turned the engine off and on about 4-5 times and the CEL cleared.
Is the RX8 that sensitive that it will throw a CEL when you remove a single fuse? The manual says that the vehicle will produce a CEL if there is an electrical problem with the vehicle.
Anyone else had a CEL from taking fuses out , disconnecting batteries etc?
Cheers
Old Jan 6, 2010 | 10:02 PM
Jon316G's Avatar
Grasshopper
Removing the ROOM fuse resets the PCM
This might interest you too:
http://www.finishlineperformance.com...3-04-1358b.pdf
Old Jan 6, 2010 | 10:11 PM
Iceman808's Avatar
Cheers for that. So I guess thats what caused check engine light to display.
It has cleared now, but I was wondering how you clear the memory of fault codes.
Cheers
Old Jan 6, 2010 | 10:12 PM
Jon316G's Avatar
Grasshopper
Disconnect the battery for ~15min.
Old Jan 8, 2010 | 08:49 AM
Taz Ismail's Avatar
TAZ
the cel light was on when i bought rx8 two months ago. when i went to the garage the mechanic said that two of the ignition coils are burnt (coil b and d). i chaged them and after 2 days the cel light reappeared. I again went to the garage and found out that 2 other coils were burnt this time coil (a and c) and in that way all the coils were replaced within 2 weeks...today i went for ride and when i started the car i saw cel again and i'm sure that its again the ignition coil problem, i've just done around 200 miles on it and I have no idea why the coils are burning again and again.....................please help
Old Jan 8, 2010 | 09:41 AM
dozer's Avatar
on his 3rd rx8
^is the CEL flashing? you should have the code read to figure out exactly what it is
vapor2
Nov 3, 2020 03:38 PM
marc2820
Jul 26, 2015 10:47 PM
dbarber
Jul 25, 2015 01:34 PM
netrovers
Jul 20, 2015 03:32 AM
