Deleting the Oil Metering Pump System
Old Jan 6, 2010 | 01:03 PM
maxxdamigz's Avatar
Baro Rex
One note though, and you touched on this, you will be swapping your oil metering from a 2 dimensional rpm/load map to a singular scalar value X% of fuel injected. Oil metering at 8500 rpms might have its highest flow rate, but I think it's actually at its highest value per unit fuel at low RPM/load. I've never gone beyond knee deep in oil metering science, but as you lean out your mixture at cruise running near stoich, the burnoff rate of the oil may increase as a function of each revolution. Certainly you can run a rotary purely on premix as it's been done for years, but did Mazda implement the variable OMP solely for convenience of the owner or is the two dimensional variable injection a more important aspect of it than you credit it?
Old Jan 6, 2010 | 01:29 PM
MazdaManiac's Avatar
1) Low mount? Why take the pump out at all if you have the room for it?
2) I'm not sure why you would get the "limp mode" since the pump is attached, but I wouldn't "zero-out" the OMP tables since the OMP isn't doing anything, anyway. Just leave the values alone. Perhaps there is a hidden "check" for pump movement at all.
3) Why not adapt an old-style metering system that injects at the intake port?
Old Jan 6, 2010 | 02:06 PM
Originally Posted by GTAW
I'm not sure how beneficial this would be considering the fabrication over premixing?
Because you can set the oiling rate to follow load, instead of dumping in oil as a fixed proportion to gas.
Maybe not a big deal, but that is how I would do it.
As you noted, Mazda decided to have a precise oil proportioning system for some reason. Whether or not its purely emissions related is up for discussion.
Old Jan 8, 2010 | 12:14 PM
rotary.enthusiast's Avatar
The Local Idiot
I've "deleted" the OMP on my car by zeroing out the same oil metering tables you did with ATR. I however left the OMP where it was since I don't need the space yet. I didn't bother suppressing the DTC's associated with the OMP, and haven't had any come on.
Review the service manual to see if there is any information about how the PCM monitors the OMP functionality. You say you "modified" the OMP... in what way? I would also check your wiring extension... it's possible that the added impedance of the harness extension itself is the problem even if the connections are all good (although this seems unlikely).
Old Jan 8, 2010 | 12:27 PM
The PCM does a check pump routine in the first 6-8 sec after startup. If it doesn't like something about the pump it goes into limp mode and the throttle is limited.
I ran into this problem doing my Haltech install. There is no code set...but it does have to do with the position sensor and pump wiring/operation. I have three pumps that scope out all the same...same resistance values..same position switch settings as near as I can tell...two of them will not work....and the third does...
Jeff: Do you have any info on the pump check routine? I know it exists...cause after a reset with the non-useful pumps the throttle works fine till the car has been started and runs for about 10 sec...then it goes into limp mode. It can be repeated after a reset
PS: you might want to fiddle with the OMP position sensor a bit...that might help.....I got that to work for about a year on one pump
Old Jan 8, 2010 | 08:49 PM
I would definitely reset the OMP values back to OE rather than zero since it makes no sense to zero them out with it disconnected from actually pumping oil into the engine. Can't say for sure, but I'm with Jeff that this may be the cause. Otherwise it makes no sense for it to throw a limp mode since it can't actually detect oil flow directly.
the only other thing that might make sense is that the new OMP connector wasn't wired as well as it should have been.
Old Jan 8, 2010 | 08:58 PM
Flashwing's Avatar
3-wheeler
Nope, the OMP certainly cannot tell whether it's flowing oil or bone dry. Don't ask me how I know.
Old Jan 8, 2010 | 09:00 PM
05rex8's Avatar
sold the 8... :(
how do you know?
Old Jan 8, 2010 | 09:07 PM
There is no flow or even oil sensor in the pump....
Old Jan 8, 2010 | 09:36 PM
Flashwing's Avatar
3-wheeler
Originally Posted by 05rex8
how do you know?
Oh you know...**** happens.
Old Jan 17, 2010 | 01:41 PM
Anything is possible if you throw enough time and money at it....BUT for me it isn't worth the work....I found it easier to just supplement the OMP with pre-mix and leave it at that. Then you don't have to fight with the PCM logic...and have less headaches
Old Jan 17, 2010 | 06:34 PM
olddragger's Avatar
one thing i dont like about not having the omp----is during high load/high rpm--you let off the gas and very little lubrication is getting to the seals.
This is like on track use or mountain driving---idle amount of premix going in but engine is at a much higher rpm.
I agree with Dan--let pre mix be a supplement.
OD
Old Jan 18, 2010 | 08:37 AM
Yes, this is my main concern after all the EMS headaches.
Old Aug 30, 2010 | 08:10 AM
ssspeedfreak's Avatar
Ok so its not simple to turn off or un-check the OEM ECU's inspection of OMP using the COBB or anything else?
I wish anyone of our reputable performance companies could figure out a delete or relocate.
Old Aug 30, 2010 | 07:20 PM
arghx7's Avatar
Somebody will have to find the limp mode system in the PCM code. Unfortunately, Cobb has abandoned the Rx-8 and opensource tuning hasn't really picked up steam.
As for OMP vs premix, well the OMP was originally developed to supply oil right to the rotor housing instead of only from the manifold as it was done on the old carbureted engines. The whole point is to reduce consumption. You can get the same lubrication effect with less oil consumption by injecting oil right on to the housing. So the first system was based on throttle position only because it had a mechanical rod connected from the throttlebody to a simple mechanical OMP.
Then in '89 Mazda implemented the stepper motor system that carried on until the Series 2 Rx-8. They figured out that at a given level of engine load, after a certain point supplying more oil accomplishes nothing and just increases consumption. Therefore they calculated oil requirements based on the airflow meter signal rather than just having mechical system controlled only by throttle position.
At a certain level of oil injection the apex seal temperature no longer decreases and thus there is no point of using more oil than necessary.
As for the question of letting off the gas on a premix only car, the channels in the chrome surface are designed to retain an oil film. I wouldn't worry too much about it. Still, you would think that after enough coasting eventually the residual oil film wwould break down and apex seal temperature would begin to rise.
Attached Thumbnails Deleting the Oil Metering Pump System-87_omp.jpg   Deleting the Oil Metering Pump System-89_omp.jpg   Deleting the Oil Metering Pump System-89_omp2.jpg
Old Aug 30, 2010 | 08:23 PM
paulmasoner's Avatar
Asshole for hire
thats the longest "i agree" that i think i've ever seen posted
