9000k rev-limit?????
Old Jan 4, 2010 | 08:20 PM
rx8montreal's Avatar
is the rev limiter really is at 9k on the rx8? because i can rev mine up to 9400k and i have not flash the ecu.....
Old Jan 4, 2010 | 08:34 PM
Flashwing's Avatar
3-wheeler
The rev limiter is set to 9,000 RPMs on the stock tune however as you climb higher in the RPM band the tachometer is more inaccurate. It's already about 200 rpms off in the lower parts of the RPM band.
The PCM reads the actual RPM amount and will limit you at 9,000 RPMS regardless of what your dash instruments tell you.
Old Jan 4, 2010 | 09:28 PM
ARE-EX-8's Avatar
Rotary > Piston
SO basically if im reading 9500 .... im actually doing 9000. HMM interesting
Old Jan 4, 2010 | 11:30 PM
At stock tune, power after 8500 rpm is dropping so fast that there is no point revving further.
The engine itself can handle MUCH higher RPM, its just that if you're not making power, wtf is the point? you're just wasting gas.
So they limit it at 9000 rpm.
You might ask why not limit it at 8500 then? well, 9000 looks better than 8500 rpm thats for sure. and the power level between 9000 and 8500 is about 5 hp. so
Old Jan 5, 2010 | 11:50 AM
Nubo's Avatar
Lubricious
An additional consideration is: where in the powerband will you be after you shift? While there might not be much power to be gained after 8500, shifting later will get you further into the power once you upshift.
Old Jan 5, 2010 | 11:53 AM
PhillipM's Avatar
^^Which is why we have a 9.5krpm limit on ours
Old Jan 5, 2010 | 01:05 PM
kersh4w's Avatar
Hit & Run Magnet
you can rev yours up to 9400k? that is amazing.
i've never seen an engine run at 9,400,000 rpms before. how much horsepower do you have? you must have the elusive mazdaspeed8.
Old Jan 5, 2010 | 01:13 PM
CyberPitz's Avatar
Huge hole is huge
I jumped into this thread expecting this post every time...then you're the only one!
Old Jan 5, 2010 | 01:38 PM
kersh4w's Avatar
Hit & Run Magnet
i cant stand it when people do that.
Old Jan 5, 2010 | 01:45 PM
damn, I missed that part
Im sure his Rx-8 can do 3 minutes or less at Nuburgring
Old Jan 5, 2010 | 02:23 PM
tubingchamp's Avatar
What mawd bug?
Yeah, I was just going to reply with 9,000,000 rev limit is HUGE, what kind of mods did you have to do? Only the ram-air intake can allow such high RPMS..
Old Jan 5, 2010 | 09:22 PM
http://www.youtube.com/watch?v=NhpbhxBEU-E
i think that now we can see what i meant when i said 9300-9400rpm cut-off!!!!
stock ecu
Old Jan 5, 2010 | 09:40 PM
Snrub's Avatar
If 9000 RPM is represented as 9400rpm on the tach due to error, shouldn't the error be something like 9000 +/- 4.4%? Alternatively it could be something like 9000 +/- 4.4% +200. Both are standard ways of expressing measurement/instrumentation error. I've never heard of a RX-8 with a fuel cut reading under 9k. Logically it doesn't make a lot of sense to calibrate the tack with an additional fudge factor to ensure it's always above 9k (that doesn't mean it isn't the case). Thoughts?
I don't think it's fair to say that the engine can handle much higher revs, at least not on a sustained basis. As Nubo said, it makes sense to rev beyond peak power to maintain the maximum amount of power under the HP curve (average engine output).
Old Jan 7, 2010 | 04:54 PM
ShottsCruisers's Avatar
Rx7 and now Rx8
stock ecu
Reving an engine like that (even a rotary) without any load on it is plain dumb. You're asking for troubles.
Old Jan 7, 2010 | 05:08 PM
What mawd bug?
See his answer?? He's going to get a 20b......
HAHAH!
Anyways, atleast it's not cold.
Old Jan 7, 2010 | 07:07 PM
MazdaManiac's Avatar
Don't forget, at 9,000,000 RPM, the rotors are only doing 3,000,000 RPM.
Old Jan 7, 2010 | 07:40 PM
ZumnRx8's Avatar
RX8 & RX7 owner
stock ecu
sounds nice & get that CEL cleared!
Old Jan 7, 2010 | 08:12 PM
He's running a Jet "V-Chip". No control over the CEL.
Looks like he's gonna switch to an Int-X, so I don't think he cares about the CEL.
Old Jan 7, 2010 | 08:18 PM
ZumnRx8's Avatar
RX8 & RX7 owner
^ thanks im googlin it, never heard of it for our cars..
Old Jan 7, 2010 | 08:41 PM
Flashwing's Avatar
3-wheeler
The rotary, by design, is capable of handling much higher revolutions. The primary limiting factor is the harmonic frequency of the apex seals which is probably around the 13,000 to 14,000 RPM range.
The secondary (and more important) limiting factors are the transmission and the airflow. The transmission isn't designed for those excessive RPMs and the engine's VE falls above 9,000 RPMs which is why there's a power drop off.
It's hard to say why there is a % error with the tach. It's not off by 400 rpms as it's more like 200 to 250 rpms but the error gets worse the higher you are in the RPM band. When I hit my 9500 RPM fuel cut my tach reads nearly 10,000 RPMs.
In my case I wanted a high rev ceiling to keep me in the power band but also to avoid hitting fuel cutoff. Various other vehicles pull timing at redline while the RX8 pulls fuel. The last thing I need is a freakish lean condition with the motor spinning that fast under full load and KABOOM. Only side effect I've found is having to run very rich above 9,000 rpms. I'm in mid to upper 11's otherwise the car gets really upset.
Old Jan 7, 2010 | 09:49 PM
Snrub's Avatar
^ Correct me if I'm wrong, but I thought chatter marks and bearing wear start to become a concern with sustained use even in the 9-10k range? I thought even the Grand Am cars (Koni and GT) run lower RPMs than realistically possible to ensure longevity. I believe the R26B in the 787B was detuned significantly detuned as well as it's race day peak power was @6500rpm.
amartin
9
Aug 20, 2022 10:27 PM
sjc5059
60
May 18, 2020 07:08 PM
CometX
Oct 4, 2009 10:43 PM
CometX
Feb 26, 2009 12:28 PM
