Burnt Transmission?
Old Jan 4, 2010 | 02:27 AM
b1gb4ng's Avatar
Burnt Transmission?
I think i have a burnt out transmission i leant my aunts boyfriends borrow my 8 for some errands. When he got back i went to the car to grab something but i noticed the smell. It lasted more than an hour. Do i have a burnt clutch ? if i do how much to fix?
Old Jan 4, 2010 | 08:38 AM
Snrub's Avatar
If the clutch is abused, etc. it can give off a smell, etc. The clutch disk is designed to wear over the course of it's life. If the smell was reasonably short lived then you're probably okay unless you notice additional symptoms.
Old Jan 4, 2010 | 08:58 AM
maxxdamigz's Avatar
Baro Rex
I lit 4rth gear up once. It stuck for a bit, but really had no ill effects.
Old Jan 4, 2010 | 09:52 PM
b1gb4ng's Avatar
They smell stuck like it lasted for a while acutally and it stunk. And i feel like the clutch is more loose. Like the firtion point is way off.
Old Jan 5, 2010 | 12:05 PM
Nubo's Avatar
Lubricious
Get going up a hill at a moderate speed and a gear that will give you about 2500 rpm. Then stomp on the gas. If the rpm increase rapidly but are not accompanied by comparable acceleration, then your clutch is slipping.
Other than that, it's hard to say how much damage a particular overheat has done. If it wasn't too bad, then the glazing of the friction surface may wear off over time on its own.
Old Jan 5, 2010 | 08:07 PM
b1gb4ng's Avatar
when i launch on a hill doesnt seems as powerful anymore. On i hill i go on all the time so i know where the point where i release the clutch and start rolling with giving it gas. But now i try it i dont roll up i just get to the point of stalling.
Shankapotamus3
Mar 14, 2021 03:53 PM
airlive
Jun 28, 2020 07:46 AM
Quiggs321
Sep 30, 2015 05:34 PM
