Tanabe SMH Exhaust: Rear Gasket?
Old Dec 28, 2009 | 03:51 PM
Jasonawojo's Avatar
Last time I had the car in the shop they mentioned I had a small exhaust leak at the rear coupling where the pipe splits into two mufflers. I was wondering where I could get another gasket for that coupling? Is there a Tanabe specific one or are they generic? I did a quick search of the web and wasn't finding gaskets specifically.
Old Dec 28, 2009 | 11:52 PM
Phalkhan's Avatar
Is this the exhaust you have? It looks like its the same size as the flange that connects the cat-back to the mid-pipe. Race Roots sell a gasket that should fit. I use these on my exhaust system and I've never had an issue with them. http://raceroots.com/index.php/produ...et-2-bolt.html
Old Dec 29, 2009 | 10:33 AM
Jasonawojo's Avatar
The one I have is actually the model below that, the Super Medalion Hyper.
I'd think it would use the same gasket though? Says 60-70mm pipe diameter, which is also what the one you mentioned is.
Old Jan 12, 2010 | 01:44 PM
Spiritus Sancti's Avatar
I believe you can get any gasket that would fit or be the same diameter as the old one
Old Jan 14, 2010 | 07:21 AM
just take the gasket to a decent auto parts store and they can likely match one up.
arexatemate
Oct 28, 2019 08:16 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
Rx8_412
Sep 24, 2015 08:51 PM
DVerdeyen
Sep 13, 2015 11:19 AM
Rupanrx
Sep 4, 2015 06:44 AM
