FD Ignition Coils
Old Dec 17, 2009 | 08:35 PM
ScottyStyles's Avatar
Tailhappy
FD Ignition Coils
Does anybody have any experience with using FD Ignition Coils in RX-8's? If so, how do they work, how do they fit, etc? I'm considering replacing my coils, and a friend has a spare coil set laying around from an FD that he'd let me have for cheap. So... any advice would be great. If it's not that good, I'm thinking of probably going with BHR's coils.
Old Dec 17, 2009 | 08:42 PM
chancejat's Avatar
Drive it like u stole it!
give it a try.....
Old Dec 17, 2009 | 09:08 PM
jfxp's Avatar
Rotor nut
Just an FYI, the FD guys swap their coils out for FC ones due to better spark/life.
Old Dec 17, 2009 | 09:50 PM
PRX8's Avatar
BHR is not a bad choice either I've had mines since April , and I'm not a daily driver , nor Turbo or even Nitrous, I will be selling the car and eventually parting out everything I have soon so , if your interested in the BHR ignition kit pm me nd its yours for a fair price
Old Dec 18, 2009 | 12:13 AM
misfire, try again .... all coils are not created equal
PS: through a set of high compression pistons in there too while you're at it
Old Dec 18, 2009 | 03:29 PM
arghx7's Avatar
The FC and FD coils are waste sparked on the leading. That means that both leading plugs fire at the same time. The FD coils aren't the best, but they are more reliable than the Rx-8 coils... they should be good to 350-400rwhp with an HKS Twin Power amplifier. But I don't think you could make them work on an Rx-8 easily.
The trailing plugs are controlled individually, but the FC and FD trigger them differently. The FC is particularly weird. It has a "select" signal, basically an on/off switch (square wave) where "ON" corresponds to one plug and "OFF" corresponds to the other.
The Rx-8 ignition system is actually a much better system design, but the components are not reliable.
Old Dec 20, 2009 | 11:07 AM
They're not compatible - period
Old Dec 21, 2009 | 02:16 AM
Tailhappy
Thanks for the responses guys. I'll probably go with BHR then. I have a friend that has an extra set of FD coils, so if they were compatable I figured I would give it a whirl.
RevMeHarder
Jun 1, 2026 02:30 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
Sakebomb Garage
Sakebomb Garage
Sep 6, 2015 03:29 PM
