Problem with my 6 Disc Changer
Old Dec 12, 2009 | 06:24 PM
RedRocket8's Avatar
PISTONS are for (|)
NJ Problem with my 6 Disc Changer
Everytime I load a CD into my player it always says " CHECK CD" on the dislpay screen, and it spits the CD out. No matter if its the actual album i buy from the store or a CD I burned, I hear it spinning and then it says "CHECK CD". The only way to get it to work is constantly load the CD for about 5 minutes. anyone know what is wrong or can help?
Old Dec 12, 2009 | 06:37 PM
invasion08's Avatar
A new cd may have rough edges on its inner and outer perimeters. Remove the rough edges in advance by using a ball-point or pencil. To remove the rough edges rub the side of the pen or pencil against the inner and outer perometer of the CD. Try that first
Old Dec 14, 2009 | 11:54 AM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Try buying a CD lens cleaner online or in the store.
Old Dec 14, 2009 | 12:17 PM
mikesol's Avatar
gas kilometerage
Yep. They're usually a disc with a little brush attached, you put it in and listen to the audio on the first track, it'll tell you what to do - usually you push the next track button at a specific time.
Run it through its routine a couple of times and it has a good chance at fixing you right up. As long as you can get the changer to play it in the first place, that is!
Old Dec 14, 2009 | 04:50 PM
RedRocket8's Avatar
PISTONS are for (|)
Ok thanks guys i'm gonna try this during my lunch break.
Old Dec 14, 2009 | 08:25 PM
Let us know if it solved the problem.
Old Dec 15, 2009 | 02:49 PM
RedRocket8's Avatar
PISTONS are for (|)
hi guys i tried everything suggested above, and still takes exhausting minutes to get the simple CD to work. I'm all out of ideas
Old Dec 15, 2009 | 03:29 PM
You might just have to replace the unit...If you do, you can find 6 disc changers on here for about $100+/-. Also you could buy the Mazda or one of the aftermarket iPod adapters. There is also the single disc player that plays MP3s. Of course, all this requires taking dash apart.
Old Dec 16, 2009 | 12:12 PM
Socr8tes's Avatar
I've got the exact same issue with the 6-disk on my '04. It sometimes takes my full 1-hour commute to get a CD to load. I've had the problem for well over a year and it's getting progressively worse. Please let me know if you find a solution.
Old Dec 16, 2009 | 12:30 PM
Try a can of air. spray in there to clean the optics.
Report back.
Old Dec 16, 2009 | 04:26 PM
RedRocket8's Avatar
PISTONS are for (|)
Report back.
Thanks Razz, at this point i'll try anything. I'll go to home depot tonight after work and buy a can and see what happens.
Old Dec 17, 2009 | 11:12 AM
Socr8tes's Avatar
BTW, if you haven't already figured it out - you don't need to let the CD eject and then reload it constantly. Just before it ejects, you can cycle power off and on, or quickly switch to FM,SAT,etc. and back to CD. That'll reset the load and you can save a few seconds each try.
Old Apr 8, 2015 | 04:07 PM
UHATEIT's Avatar
I understand that this is an OLD thread, but does anyone know the solution to the OP problem? I bought a 2004 and mine supposedly has a Bose system (cannot tell on the headunit it doesnt say anything) but trying MP3, burned CD, and regular CD it just keeps saying "CHECK CD" and will not play anything. Is there a way to reset this or check if the lense has issues?
theblinkof
Oct 4, 2023 05:24 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
