Cel code p0456?????
Old Dec 8, 2009 | 04:59 PM
bmarrs's Avatar
Cel code p0456?????
Hey guys, got a CEL code of P0456..... EVAP control system leak..
Anyone had this code before? I checked the gas cap, but not sure whatelse to check..
Old Dec 8, 2009 | 05:03 PM
dozer's Avatar
on his 3rd rx8
did you buy a new gas cap?
Old Dec 8, 2009 | 07:20 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
or................did you turn it so that it clicked about 5-6 times?
Old Dec 8, 2009 | 07:50 PM
dozer's Avatar
on his 3rd rx8
^ive noticed mine still stays on when i turn it that much
Old Dec 8, 2009 | 08:23 PM
auzoom's Avatar
Hmmmmmm.........
https://www.rx8club.com/showthread.p...ighlight=p0456
http://www.finishlineperformance.com...26-07-1800.pdf
Took me all of 30 seconds!
You CANNOT see anything by looking at the cap, you need a known good one to test it. It appears to be a VERY cheap part in the US. Go and grab one (or if you know someone with an 8 do a swap).
Andrew
Old Dec 14, 2009 | 06:43 PM
Roxie79's Avatar
My Fuzzy Mechanic
I have the P0456 code on too. It came on a few months back, right after I put in a new battery. It went away for maybe 2 weeks, and is back now. I bought a new gas cap, a standard one for the car from autozone. The guy said usually lights clear after 30 miles... mine hasn't. I also read something about 3 starts/stops to clear the mazda light. Anyone have any clues on how to clear the light, and if I need the actual mazda gas cap or if the generic one from autozone is ok?
I'm also wondering if it has something to do with putting in a new battery. In my looking (I forget where I found it now), I saw something about the vacuum line sensors and the battery.
Old Dec 4, 2012 | 06:24 PM
GK1707's Avatar
Can this code be anyway related to the cat? I recently installed a AP midpipe and a few days later got a CEL. I suspected it was the typical cat code but i got p0456 instead and cleared it. It came back today. Should I just get a new gas cap. Or is the midpipe causing this cel.
Old Dec 4, 2012 | 06:39 PM
j9fd3s's Avatar
the ECU checks the evap system after the 2nd or 3rd drive (it happens with a warm engine key off), so it might take a day or so.
if the car failed the test the light will be on right from start up, and if it passes the next test it should turn off.
Mazda part number is FE02-42-250B, list is $25ish
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
TotalAutoPerformance
Vendor Classifieds
Oct 14, 2015 12:29 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Evan Gray
Sep 26, 2015 12:30 PM
