Leveling HID headlights!!! Help
Old Nov 27, 2009 | 04:58 PM
04rx8kid's Avatar
Ok so i know there are threads out there and ive searched but i havent found the one that im looking for, i need to raise my headlights because they are pointing to low and need pics of where i use the screw driver and level them back up, is there a way to do this without touching the auto leveling sensors? thanks in advance
Old Nov 28, 2009 | 02:38 AM
Nubo's Avatar
Lubricious
Yes, they can be adjusted easily, without messing with the sensors.
Here's the procedure
And here's what the adjuster *really* looks like. You engage the teeth in the hole with a large Phillips screwdriver. You can access the adjustment through the engine bay.
Make sure you follow the badly-translated wording in the shop procedure, which I read as "always finish by turning the screws in the tightening (clockwise) direction"
Old Nov 30, 2009 | 01:44 PM
Liu Kang's Avatar
how do you install the HIDs? is there a writeup somewhere?
Old Nov 30, 2009 | 07:12 PM
04rx8kid's Avatar
not sure if theres a write-up or not, but also with leveling the lights i found where you can adjust them through the engine bay but i dont have the right tool to get at it with such small spacing, would it be easier to go thru the wheel-well and take off the plastic covering and access the lights from there?
Old Dec 6, 2009 | 07:44 PM
viprez586's Avatar
05 RX8 Sold///05 Evo VIII
Yes, at least that's what I did when replacing my HIDs.
Old Dec 7, 2009 | 10:04 AM
04rx8kid's Avatar
yeah i replaced my lights a week or so ago but still were pointing to low so i wanted to adjust them, just popped off the cover to the wheel well and it was a piece of cake, thanks for the DIY note Nubo
Old Jan 27, 2010 | 08:34 AM
slvrstreak's Avatar
Angler of the Year
did the same thing as well...thanks Nubo
Old Jan 27, 2010 | 02:56 PM
chad79's Avatar
There's a hole in the fender flange just above this adjustment point. I used a long philips driver, ran it through the hole and into the adjustment "socket" . Worked like a charm.
Old Jan 27, 2010 | 07:15 PM
slvrstreak's Avatar
Angler of the Year
yea that would have been simpler i you can see it easily...did you remove the tire?
Shankapotamus3
Mar 14, 2021 03:53 PM
Learners_Permit
Sep 27, 2015 07:38 PM
drlubell
Sep 26, 2015 11:58 PM
