View Full Version : after 5min idle, car looses power for 1 sec and comes back on??
Vikingdiesel
11-27-2009, 01:07 PM
Just happened for the first time last night, if the car its sitting in traffic or just sitting while idling for more than 5 min, it feels like the cars turns off and then turns right back on in 1 sec and it will keep doing that until I start actually driving away. When this happens, the WELCOME MAZDA screen will appear on the radio, all dash lights go on for about a sec and i loose power steering, it literally feels like I just turned the car off and turned it right back on. The power feels like its cutting in and out. When I shut the car and turned it back on, the DSP light flashes and traction control light is on and then when I turn the car off again and restart, all is good, no DSP or traction control lights? Anyone have a clue whats going on?
05rx8mazda
11-27-2009, 01:18 PM
Check your batter cables, and alternator. it has to be something electrical.
tubingchamp
11-27-2009, 02:17 PM
Could be the fan kicking in?
DarkLord7854
11-27-2009, 02:22 PM
You sure it's not losing power instead of loosening power?
Vikingdiesel
11-27-2009, 02:26 PM
yea, loosening power in my AUTO RX-8... lol
Vikingdiesel
11-27-2009, 02:27 PM
good idea, ill check that, it kicked in before all the time and no power was loss, you're saying, its taking too much power for the fans to kick in
tubingchamp
11-27-2009, 02:35 PM
Maybe not, if there's actual power loss, it would be some electrical problem. The fan can seem odd if you're not too sure what it is. It's quite loud, and could maybe seem like it's taking power?
If you're losing power, probably battery or alternator. Check your connections ontop of the battery.
Vikingdiesel
11-27-2009, 06:15 PM
could motor mounts have anything to do with it? Bc today it just happened when I pulled into a parking spot?? I feel like when it shakes (the car bc of motor mounts) it then looses power.
nycgps
11-27-2009, 08:46 PM
MAke sure your battery terminals are good.
CTrx8
11-27-2009, 08:57 PM
my money would be with nyc and 05rx8 on it being the terminals or battery cables issue.
juikster
11-28-2009, 03:15 AM
I been having an issue sort of like that, ever since I installed my TurboXS exhaust and started using amsol premix in my gas. I would start it in the mourning ( not all the times this happens) and back it out of the garage . when I get out of the car, releasing the clutch and in nuetral, the engine will surge from low Idle to a higher idle then back down again, up and down until I push the clutch back in, then it stops. weird eh!! anyways not all the time this happens.
I can only figure the car is pissed off that I didnt drive her hard the day before, you think!
Vikingdiesel
11-29-2009, 01:09 PM
i check the battery terminals and didnt see any issues, it cant be the fan, if it were the fan, it would blow the fuse again, it would blow a fuse before it would pull the power from the battery
Vikingdiesel
11-30-2009, 07:39 PM
it actually feels like it wants to stall and it finally did, it stalled when I turned into a parking spot but started right back up
Vikingdiesel
12-03-2009, 10:03 PM
ok, so today, it snowed and was super cold (started up like my snowmobile) windows were frozen, when I went to try to open them, all my console lights and radio turned off for a few seconds but car was still running. Then I pressed both window switches, and the lights all turned off but engine didnt die this time, while I was driving though the neighborhood, the heat was blasting and rear winow defrost was on and once again radio and console lights all started loosing power and once again, traction control light came on. Then I turned the car off when I got home and car lost all power completely, as if there was no battery and I go to turn the key in the ignition and power came back on and car started right up. Where am I loosing this power and electricity from?
Lebren
12-03-2009, 11:02 PM
Resetting ECU may help buy your issue seems like a lot of the failing alternator issues I keep seeing.
Vikingdiesel
12-03-2009, 11:33 PM
so failing alternator? how about resetting ECU, how do i do that?
Lebren
12-03-2009, 11:56 PM
Basically pulling the negative terminal, wait 30 min, plug it back and calibrate the power steering by following the steps here: http://www.rx8blog.com/dynamic-stability-control-recalibration/
you should be ready to roll. If you can have the alternator tested.
