AFT and powertrain warranty ???
Old Nov 25, 2009 | 02:57 PM
Pico's Avatar
It's Complicated
ATF and powertrain warranty ???
Ok guys I'm getting to be the time flush my ATF. My question is this, if I use a brand like RP, Redline, Amsoil, etc will this effect my Power-train Warranty?
I ask this because i was told by a tech that the OEM fluid is a clear color (Volvo) and the brands listed above aren't clear in color. So if there ever is a problem the dealer would see the difference in color when the pan is removed and possibility void the warranty.
I also called Finishline to get a price on the OEM fluid and it cost about $11 a quart and to do the complete flush it will roughly take 12 quarts -- So I'm looking at 135 for just the OEM fluid-- which is also a synthetic. Aftermarket ATF fluid will roughly cost the same as the OEM. Any info you guys could also give for a place with lower prices would be appreciated also
So here's my dilemma
Should I just flush with the OEM IF using an after market fluid will effect my warranty? I know a lot of people have made this conversion that why I ask
What I want to do is go with RP in both the tranny and diff if the warranty question I posted isn't an issue. Good combo?
BTW-- i did a search and couldn't find the answer to Warranty question--- there really isn't all that much info for the AT.
Thanks for listening to me ramble on.... Any help would be great
Old Nov 25, 2009 | 03:02 PM
Hey Pico,
Our owner manuals do not rule out using specific brands, they simply tell us what type of fluids are acceptable and which are not.
As long as the fluid you are using complies with the recommendations, then you'll be fine.
I used Royal Purple in my last transmission (M/T) and it hated the stuff. It literally started grinding as soon as I left the shop. Was it the fluid or did the fluid simply expose an existant issue with my synchros? Don't know but I do know that I talked a friend of mine into switching to RP (he was using Redline) and he too experienced griding.
Both of us ended up needing to replace our transmissions.
I'm not trying to scare you but rather simply share my experiences with Royal Purple. I have since exclusively used Redline and have zero problems to report.
I think you would be fine going with an aftermarket brand as long as you choose wisely.
According to my 2005 Owner's manual the requirement for Automatic transmission fluid = ATF M-III or equivalent (e.g. Dexron® III)
As long as you use that, the dealership can't void your warranty
Old Nov 25, 2009 | 07:04 PM
Pico's Avatar
It's Complicated
I saw the types in the manual that are recommended and that's what raised the doubt about the fluid conversion.
Phil uses the RP in his 4port AT and says he love it-- has no problems even with the SC and raised redline. That's what had me leaning towards RP.
Dexron III would be what I'd go with. I was also thinking the about the warranty as well
Old Nov 27, 2009 | 06:43 AM
use whatever u want
keep it at the right spec
keep the receipts
say f u to dealerships
Old Nov 27, 2009 | 10:17 AM
ken-x8's Avatar
If the transmission worked ok with the original fluid, why switch to something different?
Ken
Old Nov 27, 2009 | 10:50 AM
sometimes it's cheaper then buying "mazda" lubricants
Old Nov 27, 2009 | 01:10 PM
Pico's Avatar
It's Complicated
The reason for the possible change in type of fluid is that its time for a flush and thought i'd might try something different that's all.
OEM fluid seemed to work fine. However, after reading the threads about ATF fluids it just made me think of switching because other fluids have a higher temperature threshold.
Actually the quote I got for the OEM fluid was a couple buck more then the other options.
Old Dec 11, 2009 | 03:59 PM
Pico's Avatar
It's Complicated
Flush complete
Went with Royal Purple Max ATF and Royal Purple in the Rear Diff as well
There is definitely a noticeable change in the way the car drives. I would recommended using RP ATF and gear oil and will use it in the future.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
R3Dream
48
Mar 12, 2016 01:44 PM
duworm
Oct 1, 2015 04:57 PM
XianUnix
Sep 29, 2015 03:48 PM
