SSV Noise and shaft play?
Old Nov 21, 2009 | 03:55 PM
gforce3s's Avatar
Im having trouble with a friends 2004 rx8 auto trans car, the ssv was making a terrible noise at idle, just a loud ticking, so we replaced the ssv with a used one. Now, the ssv is making a bad bearing noise at around 5500 rpm and up, and also is making the same noise that sounds like bad bearings throughout the rpm range randomly. At idle i can take my hand and move the ssv shaft in and out approx. 5 to 8 thousanths, and when i move it like that the bearing noise can be heard and is very bad. Can the ssv shaft wear so much that it has excess play and create a very terrible sound at high rpms?
Old Nov 21, 2009 | 04:05 PM
Shouldn't be like a bearing noise case it isn't turning...sure it's not your alternator belt?
The actuator might have a hole in the diaphragm and whistle??
Old Nov 21, 2009 | 04:10 PM
gforce3s's Avatar
ya im sure its not the alternator belt, checked everything i could. the actuator is operating properly too, it only is making noise when i grab the acutal shaft of the ssv and either pulling it out, or pushing it in/wiggling it around
Old Nov 21, 2009 | 04:16 PM
Jon316G's Avatar
Grasshopper
Did you remember to install the SSV gasket?
I agree with dannobre in that it could be a very small puncture in the actuator's diaphragm.
Can you hook up a vacuum gauge to it, apply 10in. Hg, and see if you slowly loose vacuum?
Old Nov 21, 2009 | 04:19 PM
gforce3s's Avatar
Yes the gasket is in place, i will go double check on the actuators diaphragm right now.
Old Nov 21, 2009 | 04:25 PM
gforce3s's Avatar
the actuator is holding 10" perfectly, not dropping at all
Old Nov 21, 2009 | 04:26 PM
Jon316G's Avatar
Grasshopper
I just thought about this...
You mentioned replacing the SSV, did the other one come with the actuator already attached?
Old Nov 21, 2009 | 04:29 PM
gforce3s's Avatar
Yes it did, the original actuator was wasted, diaphragm totaly blown through.
Old Nov 21, 2009 | 04:48 PM
maybe re-re the original valve and the new actuator.......that's where I'd start
Old Nov 21, 2009 | 04:51 PM
gforce3s's Avatar
ya we are thinking about doing that...the old one was of corse caked in carbon and such, and was actually stuck closed. not sure what we will do here... the old one has a lot of play too, which makes me nervous that ill clean it up, put it in, and get the same results
Old Nov 21, 2009 | 04:54 PM
they aren't really tight tolerances....especially cold. The alum expands a fair amount when warm and it will likely tighten up a bit
Clean the old one off and lube it a bit on the bushing and try that...also check the gasket and make sure it's sealing
Old Nov 21, 2009 | 04:57 PM
Jon316G's Avatar
Grasshopper
+1
I apply a light coat of high temp grease on the bushing whenever I reinstall the SSV.
And I use carb cleaner with some q-tips to clean the valve itself.
gforce3s's Avatar
will do, thanks for the help
Old Oct 18, 2020 | 11:08 AM
djgoulty's Avatar
Where is the ssv bearing located?
Old Oct 18, 2020 | 11:10 AM
djgoulty's Avatar
Is it an easy job to replace the ssv bearing or does it need to be on a hydraulic ramp to gain access?
Old Oct 21, 2020 | 04:17 PM
usually they wobble out the hole where the actuator plate is pressed onto the shaft. Usually has to be replaced when that happens. There is no way to really grease it except where the far shaft end slides into the bushing at the far inside end of the intake manifold. Pretty sure the other end at the mounting plate is also a bushing rather than bearing. If it’s not turning easily either it’s gunked up inside, mane was dropped and bent, or is just due for replacement.
RearDriveNinja
24
Apr 5, 2021 07:08 AM
tonyjms2005
Dec 4, 2015 03:47 PM
DHPrx8
Nov 6, 2011 07:42 AM
robsrx82004
Jun 25, 2011 07:04 PM
dvd2000
Dec 1, 2009 05:39 PM
