View Full Version : Changing the lights on my 8
RedRocket8
11-21-2009, 02:35 PM
Hey guys the only mod i want to do now is change the fog lights and turn signal lights and license plate light into the same color as the xenon head lights. I was just wondering if theres anything else i need to do besides buying the bulbs? Also does anyone know the number i need for the change? i searched i got 194 and a bunch of other numbers, just want to make sure, thanks.
Turn signal light: # ?
Fog Light: # ?
License Plate Light: # ?
Jedi54
11-21-2009, 02:38 PM
Never fear, Jedi is here!
achieving the desired look should be pretty simple since most of the ligts you want to change can accept 'plug and play' bulbs. (no wire cutting, splicing, etc needed)
Turn Signal: (7440) what are you looking to put in here? You could go with a PIAA type bulbs which should be a bright white color. I changed my blinkers to 'stealth bulbs' ie; they have a chrome look to the outside but blink Amber when in use.
Fog Lights: (H11) I have a set of bulbs from http://www.hoen-usa.com/fog.htm which I think work VERY well. (pic included at the bottom)
License Plate: (194) http://www.v-leds.com/Exterior-LED/CornerSide-Marker-LED/White-LED/2-HID-6K-WHITE-HIGH-POWER-p4481133-1-2.html
Here is a popular thread with some great suggestions in the 1st post for what bulbs to use. http://www.rx8club.com/showthread.php?t=158590
Here's my fog lights.
http://i32.photobucket.com/albums/d37/Jedi54/P9091613.jpg
RedRocket8
11-21-2009, 02:46 PM
well my clear corners have the stealth bulb I can live with that. But everything else in the front i would like to have the same color has the stock headlights if you know what i mean. Like that xenon blueish white.
Jedi54
11-21-2009, 02:53 PM
check out the link in my last post, the guy who started that thread has changed out all his bulbs and I think that's the look you're going for.
RedRocket8
11-21-2009, 03:11 PM
thanks jedi thats actually the exact look i was going for. With regards to the turn signals i dont want to change the back because i think in NJ its illegal to change the back. I just want to change the front lights exactly how it is on yours. thanks for all the help really appreciate it.
RotaryP7
11-21-2009, 04:19 PM
Yea, I just bought some lights for my fogs, parking lights, and side markers. I bought an LED light for my license plate but it doesn't light up.. Ghey..
Jedi54
11-21-2009, 04:25 PM
did you switch it around?
Mazurfer
11-21-2009, 04:36 PM
^.......+1.
Put the old bulb back in, if it lights then you either have a bad LED or in backwards. Yes....it can matter!
Jedi54 runs very close to what I have......for the most part.
My list......however, I'm sure a lot of the links are bad now, but I think you will get the idea.
Parking lights.......white 6 LEDs http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Clear Corners.......white 6 LEDs http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Door Courtesy lights.........blue 6 LEDs http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Map Lights..........blue 5 refractor LEDs Don't think they sell these anymore????
Rear Dome..........blue festoon/LED http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Glove..............blue 6 LEDs http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Footwells, have two blue LED circuit boards each side(driver and passenger), these are a little more subtle that what you've probably seen.
Under the front seats(near the rear), I have RR's blue circuit boards tied into the Courtesy and Footwells above.
http://www.rx8club.com/showthread.php?t=118507
Turn signals.........Stealth bulbs for now. http://www.stealthauto.com/Departmen...lth-Bulbs.aspx
Inside Trunk.....blue 6 LEDs http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
License plate......white 6 LEDs http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481 Now changed to an HID LED.
Brake lights........18 LED 7440/7443 red http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
Back up lights.........18 LED 7440/7443 white http://www.v-leds.com/Shop/Control/P...d/0/SFV/32481#
Fog lights...........Hoen H11's. This isn't where I bought them, but see............ http://www.hoen-usa.com/fog.htm
Puddle lights courtesy of Shazbot. http://www.rx8club.com/showthread.php?t=118822 BUT.....I did change out the LEDs to match those in the door courtesy light position.....see above.
RX8Strakes Stealth brake light, but I believe they stopped making them. http://www.rx8strakes.com/index.asp?...PROD&ProdID=31
Jedi54
11-21-2009, 04:46 PM
I've changed all my LEDs (again) so I need to post an updated list soon. :o:
Mazurfer
11-21-2009, 04:48 PM
^........me too! I was just lazy and put up the old list!
Thinking you are probably using VLED's still for the most part right?
RotaryP7
11-21-2009, 04:49 PM
Yea, both sides.. It's weird. I first bought the LED to replace the old bulb since it stopped working for some reason. And I'm still getting no light there.. I made a thread about it. I'll need to check the wires I guess in the trunk.. :sad:
REsuperD
12-10-2009, 01:26 PM
anyone has experience w/ rx-fx (rx8strakes)'s fog light bulbs? they're 1/2 the price of hoens
