Oil Pressure Sensor Wiring Layout
Old Nov 14, 2009 | 11:30 AM
Jon316G's Avatar
Grasshopper
I bought a used Lotek pod and it came with ProSport gauges and sensors.
Going through the box of loose wires trying to organize and figure out what goes where, I found the harness that connects to the oil pressure sensor had its wires pulled out.
I removed the pins and hoped to see some of the wire insulation still crimped so I could tell the wire color layout.
Of course it didn't and I'm not sure what the wire layout is.
I have no problem re-crimping (and probably solder) the wires onto the pins, but I need to know the wire color layout for this harness.
Anyone with the ProSport oil filter adapter/spacer block able to help out with a pic of their harness showing the wire colors?
Old Nov 14, 2009 | 11:37 AM
yeah i have it, I will take a pic when I get home from work. But honestly I bought my adapter and gauge used and when I called the customer service was great, they explained everything to me. I even order a new wire from them for super cheap and the shipped it ASAP.
Old Nov 14, 2009 | 11:51 AM
Jon316G's Avatar
Grasshopper
Thanks for the help 9krpmrx8... appreciate it.
And its good to know I can call ProSport if I run into any problems.
I have anything laid out and separated now.
Everything appears to be simple to follow/trace, but I'll probably just install new wires and connections along with some heat shrink.
Only thing left is to figure out what to tap the power into.
I know there is a thread, just have to find it
Old Nov 14, 2009 | 11:59 AM
My gauge is in a vent pod to the left of the steering wheel so I tapped the room fuse for constant 12V. Search for a thread titled "Prosport Gauges" there is a lot of info in that thread.
Old Nov 14, 2009 | 12:02 PM
Jon316G's Avatar
Grasshopper
I'll check that out.
Thanks again 9krpmrx8.
Old Nov 14, 2009 | 02:39 PM
Here you go man.
Old Nov 14, 2009 | 02:43 PM
Jon316G's Avatar
Grasshopper
AWESOME!
Thanks again!
Old Nov 14, 2009 | 02:44 PM
No problemo. I'm installing my new Oil Tempo Gauge so I'm under the hood anyway.
mr. GrandGame
Sep 9, 2025 10:41 PM
9krpmrx8
Nov 5, 2015 11:45 PM
talonhart2
Aug 26, 2015 04:14 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
stickmantijuana
Jul 19, 2015 10:33 AM
