Help Installing RE Amemiya intake
Old Nov 14, 2009 | 11:18 AM
big_ki's Avatar
Hi People i'm new here
I've just got a RE Amemiya carbon intake for my car and i dont have any instructions on the how to fit it.
If any of you guys are able to offer any help that would be brilliant.
Thanks People
Old Nov 14, 2009 | 11:26 AM
dozer's Avatar
on his 3rd rx8
it should be a direct swap...just unplug the maf sensor, loosen the clamp with a crew driver and take out the stock air box, and replace it with the new one
the stock airbox will be a little hard to take out, youre gonna have to push it hard to get it out
Old Nov 14, 2009 | 12:04 PM
jessedrifter's Avatar
so cal
dozer has all your re amemiya needs.
Old Nov 14, 2009 | 02:11 PM
big_ki's Avatar
ok thanks i've fitted it now
just another 1 q for you guys
below 4000 rpm does the car sound quite normal inside the car
and about 4500 it becomes a load buzzing noise when you plant the go pedel??
cos mine sounds like that and sounds like there;s something loose inside vibrating
Old Nov 14, 2009 | 02:14 PM
so cal
check all nuts and bolts.. make sure everything is clamped on correctly. just double check yourself. you dont want any thing coming undone or lose. it can be very bad for you engine. and good choice with the "RE" intake. : )
Old Nov 14, 2009 | 03:24 PM
big_ki's Avatar
cool i'll double check in the morning
thanks for the help
Old Nov 14, 2009 | 06:46 PM
04RX8man's Avatar
Rotary Powered Countryboy
the aftermarket inatake will be louder but like Jesse said check all connections/bolts/nuts etc etc...you don't want a vacuum leak and start runnning lean(until the fuel trims would take over)....
RXFEVER
Aug 29, 2018 10:14 AM
WranglerFan
Nov 5, 2017 09:35 AM
RXFEVER
Sep 11, 2016 02:51 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
