Discoloration Found Inside 2004 RX-8 Transmission
Old Nov 5, 2009 | 10:58 AM
Booster MPS's Avatar
A week or so my car began to make a very noticeable noise that sounded very much like a "whir", "grrrr", or grinding of gears. I took the car in and the sound was tracked down to the bearings along the transmission shaft. Upon further investigation when the transmission was opened, they found additional wear leading them to the diagnosis of the whole transmission being on it's way out due to wear of components. The odd thing that is not understood is the orange discoloration found inside when the housing was opened. Any thoughts on what this might be would be appreciated.
Note that the car has never been driven hard, raced, and has about 73,000 miles. Thanks in advance for your help.
Attached Thumbnails Discoloration Found Inside 2004 RX-8 Transmission-4078305912_6699cebaf8.jpg
Old Nov 5, 2009 | 11:06 AM
gear oil not doing its job properly ?
Old Nov 5, 2009 | 12:41 PM
I am not sure but I will ask that question.
Old Nov 5, 2009 | 12:50 PM
mazdaverx7's Avatar
RX-Heaven
is the discoloration etched into the gears or is is a liquid sitting on top of the gears?
Old Nov 5, 2009 | 01:15 PM
olddragger's Avatar
rust.
OD
Old Nov 5, 2009 | 01:28 PM
It is difficult to describe but I would say that it looks more like it is on top of the gear as if it were painted. It almost has a slick appearance which is odd.
Also, the areas that are coated are completely coated as if done with a brush to a consistent finish. It really does not fade in or out in any of the locations. It's either clean, or that orange color.
Old Nov 6, 2009 | 12:27 AM
Nubo's Avatar
Lubricious
Wild guess - plating out of extreme-pressure additives
Old Nov 6, 2009 | 12:39 AM
rust ? ... really ...
should there be rust? gear oil should be "flying" around at all times in there.
Old Nov 6, 2009 | 05:35 AM
Assuming it had gear oil in it
looks like rust, but a picture is no substitute for inspecting the real thing. That it appears to be untouched in the gear teeth contact area on the lay/countershaft is especially odd
a bit odd for sure
Old Nov 6, 2009 | 06:51 AM
Huey52's Avatar
Registered Zoom Zoomer
olddragger was being facetious (unless it was ridiculously low on oil).
Odd intend!
Old Nov 6, 2009 | 08:47 AM
olddragger's Avatar
yes I was---thanks for clarifing and sorry if it came across differently.
It was a word that I used because i have NO idea what that could be. Unless it is a factory coating of some type.
Appreciate the pics
OD
Old Nov 6, 2009 | 09:48 AM
a bit odd for sure
Agreed that it is odd the coloration is in the teeth contact area. It seems randomly spread on different components inside. Very random.
ouimetnick
25
Sep 14, 2023 01:44 PM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Redheddude222
Aug 24, 2015 09:14 AM
Mr.Durden
Aug 12, 2015 02:21 PM
