AC help, half warm half cold. Help.
Old Nov 4, 2009 | 05:22 PM
TX AC help, half warm half cold. Help.
Okay so its been cool so i haven't used the AC much but today at lunch it was hot so I turned it on and the vents on the left side were blowing warm (almost cool, but not quite) but the right side vents were cold as normal.
I tried searching for a diagram of the AC system but couldn't find it. Any ideas?
Old Nov 4, 2009 | 08:00 PM
wow, you got something new everyday do ya ?
sorry, no idea
Old Nov 4, 2009 | 08:02 PM
JinDesu's Avatar
went back to srsly broke
What happens when you close the vents on the right side?
Old Nov 4, 2009 | 08:27 PM
The left is still warm. Although the middle right one cannot be closed.
Old Nov 4, 2009 | 10:13 PM
maybe you have a hole somewhere in there? so the engine "heat" affect the vents?
or maybe the heat-exchanger got some **** thats blocking flow ?
Take the glove box away and check that area first maybe ?
Old Nov 5, 2009 | 01:17 AM
set you search engine in advance search to any date. do a search for it..
it was a know problem, but did not happen often.. i think there was a tsb for it.
if you dont find it send me a pm an i will try to hunt it down..
was an issue in 05.
Old Nov 5, 2009 | 08:29 AM
known problem ? ... really ...
damn Im a n00b.
Old Nov 5, 2009 | 11:37 PM
Thanks Swoope!!!! Found it!!
http://www.finishlineperformance.com...02-04-1338.pdf
Old Nov 6, 2009 | 12:38 AM
Yours is a 04? I didnt know that. keep on thinking you got a 05.
Hmm ... I never got that problem
Old Nov 6, 2009 | 08:19 AM
Holy Fawk $$$$
The AC amplifier is $663.00.
Nope, mine is a 2004. Wow I have had this car a while now.
Old Nov 6, 2009 | 08:31 AM
Originally Posted by 9krpmrx8
Holy Fawk $$$$
yea, the amplifier is #@$)*#@4 expensive.
Its just a small piece of **** ... blah, electronic crap cost more ?
Get it used ---- Junk yard ppl probably gonna sell one to you for maybe 20 bux (cuz they dont know how much they worth ... I think
Old Nov 6, 2009 | 08:58 AM
Yeah, I'm gonna call around.
Old Nov 7, 2009 | 11:23 AM
LFRx8's Avatar
I had the same problem about six months ago, it wasn't the AC amplifier. The freon was low. I bought a can of freon with leak sealer and that sloved the problem.
Old Nov 7, 2009 | 10:09 PM
if thats the case, I would try to find the leak and replace the part.
Cuz leak sealer means it will leak again ---- its just a temporary solution.
When I got my FC it has a horrible leak. Its a pain to trace it down, the hole is at like the very bottom corner of the condenser. Cant even see it with UV dye and I keep saying wtf to myself. Took me couple of days to finally see that leak with UV dye, replaced, took the compressor out, flush 3 times, check, bleed, and finally add freon again, ice cold A/C (Freeze12/R12 rox, ******* hate R134a)
cliffkemp
Dec 24, 2024 10:48 AM
Evan Gray
Nov 24, 2015 01:00 AM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
GranTouTou
Sep 30, 2015 06:11 AM
Jb4ker96
Sep 27, 2015 10:06 PM
