Aux Light Question....
Old Nov 2, 2009 | 04:11 PM
ei8ht's Avatar
Resu Deretsiger
Talking Aux Light Question....
Is there a mod so you can run with the aux light (fog light) on without the headlights on. This would make a good daylight running light. I did not see this in the FAQ's so please no flames if this is old stuff. Tnx Jim
Old Nov 2, 2009 | 04:13 PM
xun4gvn4everx's Avatar
True love is blue x2
You can directly wire your fog lights into your running lights. Then you can run with the fog lights and running lights on without the headlights.
AJRx892's Avatar
yes there is a foglight rewire i believe it to be in the DIY section check there
Old Nov 2, 2009 | 04:16 PM
yes, it's possible to rewire them.
go to the Do It Yourself subform and search for the "foglight rewire" thread. Its' a pretty simple rewire. Not sure how effective the stock fogs will be as DRL's but it's worth a shot. (though I'd recommend you upgrade the bulbs)
Old Nov 2, 2009 | 04:18 PM
HWK11's Avatar
Lighting Yellow
http://koczarski.com/RX8/Mods/FogLight/ReWire.htm
Old Nov 2, 2009 | 04:25 PM
db_8's Avatar
read on:
https://www.rx8club.com/showthread.php?t=11737.html
Old Nov 3, 2009 | 05:30 AM
ei8ht's Avatar
Resu Deretsiger
Thanks for the direction to the DIY area.
Lots of good stuff there to check out.
Jim
cliffkemp
Dec 24, 2024 10:48 AM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
xAgyex
Sep 28, 2015 08:54 AM
Evan Gray
Sep 26, 2015 12:30 PM
